rebuild your door stay, a pictorial guide |
davesprinkle |
Mar 12 2006, 01:18 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
What you'll need:
1. One worn door stay mechanism. If you own a 914, you probably have two. 2. A bench vise, bolted to a bench. 3. Replacement door stay and replacement rollers. (Here's the shameless plug -- I have these available for sale.) 4. Blade screwdriver for removing and replacing springs and clips. 5. Wheel bearing grease. 6. Eye protection. 7. 20 minutes. OK, the first step is to remove your door stay mechanism from the door. I won't cover this step here. It's pretty simple, but if necessary, refer to this article on the Pelican Parts website. Install the mechanism in the vise, clamping on the door stay itself. Attached image(s) |
davesprinkle |
Mar 12 2006, 01:22 PM
The second step is to remove the springs from the mechanism. I don't think I need to remind you to wear eye protection for this step. Be sure to watch carefully where the spring goes when it leaps across the room.
Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 03:14 AM |
