V8 Engine Mount bolts...how did you drill out?, Question for V8 guys.... |
nine14cats |
Mar 12 2006, 11:51 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
I'm continuing my work on JLO (V8 SBC 914). The engine crossbar mounting bolts that attach to the frame of the car are about a 1/4" larger than stock 914 bolts. I'm using the RH hardware.
My question....did you guys dry fit the engine up where it connects, mark and then drill? Or are the tolerances of the RH parts exactly center to the Porsche stock cross bar and I just center the engine mount tabs in the drill press and open them up? Thanks in advance for the help. Bill P. |
Dr. Roger |
Mar 13 2006, 05:19 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
yes bill,
now that i think about it i believe i did have to go up one size on that hole and i did use RH's supplied bolts. be sure to push the bolts trugh from below so the extra threads are above. won't get hit on speed bumps... |
Lo-Fi Version | Time is now: 20th May 2024 - 06:59 AM |
