Temperature Sensor, Anyone know the resistance? |
billd |
Mar 14 2006, 11:53 AM
Member Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 |
My temperature gauge always reads at the left extreme of the scale. While I'd like to think my engine is always running cool, I don't believe it.
I measured the sensor. It measures 2.3K ohms cold and 300 ohms hot. I checked the gauge. 300 ohms barely moves the needle. It takes a resistance of 50 ohms to get to full scale. Does anyone know what the correct resistance range is? I suspect I have the sensor for the aftermarket VDO gauge hooked up to a stock gauge. Pelican wants $30 for an OE senso while the aftermarket VDO sensors at $10 at Summit. Anyone know a less expensive solution? It would be cheaper to replace the gauge - the VDO gauge is $25 at Summit, but the 2.062 inch gauge won't fit into the 60mm hole (2.362 inch) in my center console. |
toon1 |
Mar 14 2006, 12:04 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
the Pennington book say's, 3k when cold, 1k when warm, engine temp sensor
billd |
Mar 14 2006, 06:58 PM
If this is true, then I suspect my gauge is bad - although that's an unusual failure mode for a galvanometer.
Anyone have a nice looking solution for the 2 1/16 inch gauge in the 60mm hole? |
lapuwali |
Mar 14 2006, 08:03 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
You can make a new front panel for the center console fairly easily, and redrill the holes to be any size you like.
You can also make a sleeve out of wood with a 60mm OD and a 52mm ID. You can send the gauge to PA Speedo to get it fixed and calibrated. |
bd1308 |
Mar 14 2006, 08:13 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
maybe the guage sender wire is grounding out somewhere?
b |
billd |
Mar 15 2006, 05:41 PM
egauges.com lists 10-180 ohms as the resistance range of a VDO temperature sender. If this is true of the stock sender, then my gauge is about right and I just need a new sender. I've ordered the aftermarket sender from Summit ($10) and will see if this works.
BMartin914 |
Mar 16 2006, 08:09 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
You need to make sure that you get a sender that matches your gauge. The older gauges use a hotter sender, the later ones a cooler one.
The older senders are NLA, and what is being made new are 150' C senders. If your gauge pegs at 300' F, this is what you want. If you have an older gauge, the 150' C sender will not be accurate. *All of this information is assuming you are referring to the oil temp sender* |
Lo-Fi Version | Time is now: 20th May 2024 - 10:03 AM |
