Tires and torsion bars |
JJ914 |
Mar 15 2006, 01:41 PM
Big JJ Group: Members Posts: 90 Joined: 30-December 04 From: Augusta GA Member No.: 3,374 Region Association: None |
Hey,
Two ?s. First I am thinking of go to 195/55/15. Can anyone tell me if they have had good luck with that size tire. There going on the the EMPI style 8 spoke mags. Also has anyone adjusted there (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) front torsion bars, my left side is lower than my right. Thanks, Jason 72' 914 1.7 Saturn Yellow |
Joe Ricard |
Mar 15 2006, 01:59 PM
Yea your tire size will fit the wheel and also fit up under your fenders no sweat.
Torsion bar???? nah we just talk abpout 914's we don't actually know how to work on them (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Seriously this is one stop shopping for fixing your 914 the Torsion bars can be adjusted by truning the "adjusting bolt found at the rear of the torsion bar. Either a 8mm allen scocket or 11mm hex head. Be sure to relieve some pressureoff the suspension before turning bolt or you could strip it. |
Jaiden |
Mar 15 2006, 02:21 PM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
If those EMPI's are VW offset then those tires will rub unless you roll the inner fender lip and pull out the fender openings 1/2"
Ask me how I know!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Joe Ricard |
Mar 15 2006, 02:27 PM
How do you roll the "inner" fender lip?
I'd like to know cause my slicks rub the inner fender just a tad while pulling 1.4 lateral G's don't come close to the OUTER fender. |
Jaiden |
Mar 15 2006, 02:32 PM
I mean the inner lip on the fender. I did mine with two blocks of wood and a large pair of channel locks and slowly worked from the center out and then just gave a tug on the fender it bring it out a tad. THe PO did one side and screwed it up now the rear fender sort of looks crappy.
All I know is the lip is not on the OUTSIDE of anything so it must be an INNER lip (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Joe Ricard |
Mar 15 2006, 02:44 PM
I hate me on days like this. Sharting shit for no apparent reason. bored out of my skull, 80 degrees outside and sunny. I'm stuck infront of this damn box.
I wanna go work on my race car. |
Jaiden |
Mar 15 2006, 03:00 PM
you sound just like me!! HA HA although I don't think I have the post count to start anything around here without getting my ass whooped!! |
JJ914 |
Mar 15 2006, 03:46 PM
So would 185/60/15 or something different fit better than the 195-55s. Rolling the fenders seems a bit scary (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Mueller |
Mar 15 2006, 03:47 PM
what size do you have one there now?
JJ914 |
Mar 15 2006, 03:48 PM
165R15 I call them rudders
JJ914 |
Mar 15 2006, 08:52 PM
What size tire is best for my rims. I want something better handleing without having to roll fenders
Jaiden |
Mar 16 2006, 07:55 AM
If you go with a 185 tire you should be good on the VW offset empi's but double check you might have a porsche offset empi style rim as they do exist.
Just make sure you check the offset or backspacing to verify. If you have the proper offset you should be able to run a 205 tire. |
Joe Ricard |
Mar 16 2006, 08:16 AM
Or buy my Mahles. with tires on em.
195/60-15 |
rhodyguy |
Mar 16 2006, 08:26 AM
doing body damage, to run a set of wheels that are worth $150 tops (used, set of 4) never made any sense to me. as stated, you MUST measure the back spacing. from the inner wheel face to a straight edge laid across the inner lip of the wheel. off hand it's about 4 5/8" on a oem 4 lug fuch, iirc. i'll measure exactly later.
k |
Joe Ricard |
Mar 16 2006, 08:52 AM
My set of FUCHS were 4 1/2" as were my Pedrini and the Mahles also.
rhodyguy |
Mar 16 2006, 08:58 AM
or 9/16". (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) if the back spacing is too shallow, save up for some proper wheels for your new tires.
k |
JJ914 |
Mar 16 2006, 09:45 AM
JOE,
Can you give me a price and a pic. |
Joe Ricard |
Mar 16 2006, 10:15 AM
You got mail.
JJ914 |
Mar 16 2006, 06:55 PM
Just measured my backspace and it is 4 inchs. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I guess that explains why my little tires are so close to the fenders.
Joe Ricard |
Mar 16 2006, 09:35 PM
Interesting because the Empis I have owned (4 sets) were less than that even 3 3/4". So glad I sold all of them as they were heavy 19lbs and did infact limit tire sizes. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:58 PM |
