Rocker Panels, Fix the holes |
TINCAN914 |
Mar 16 2006, 02:26 PM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
Bought a new 73 a few weeks ago, pulled the panels off after drilling out the rivets. They had been drilled before when the PO went Fi to Carbs, but he went and put rivets in again, only larger. The F***G holes are 1/4" dia. I went and bought some pan head screws to replace the rivets, but there they like a pimple on the end of your nose. I thought I would ive with it until I got around to painting it again then weld the holes. Any suggestions?
The good news was no rust... (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Mueller |
Mar 16 2006, 02:49 PM
there should be no reason to remove the rocker panels to even touch the motor....carbs or FI, no differance...
TINCAN914 |
Mar 16 2006, 02:59 PM
Well it appears there are fuel lines running under the panels. Def hose... I just assumed that's what they were.. Did I just step on my D**K? |
Mueller |
Mar 16 2006, 03:05 PM
fuel lines go thru the center tunnel....the only lines that go on the outside of the vehicle are for A/C and the charcol evaporative system (depending on year)...if the PO installed fuel lines behind the rocker panels, he needs to be hunted down and kick in the nuts (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) |
TINCAN914 |
Mar 16 2006, 03:10 PM
Well SEEEEEEITTTT. I guess I will be tracking those lines down.. THe car did not have A/C...
MattR |
Mar 16 2006, 03:14 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
On the drivers side? I bet its the charcoal cannister lines.
TINCAN914 |
Mar 16 2006, 03:21 PM
Yes Matt, as I recall 1/2 or 3/8" lines, two of them, driver side only.. OK what are they for? |
Mueller |
Mar 16 2006, 03:23 PM
evap. system, helps with the gas fumes from the tank.... |
MattR |
Mar 16 2006, 03:24 PM
Fuel injected cars had charcoal cannister to clean the air or something. I dont know the details on how they work, but I know my webers dont have a provision for them, so I yanked my lines too. Looks like someone did the conversion right if they went through the trouble of removing the lines and not just cutting them at the firewall! |
Mueller |
Mar 16 2006, 03:27 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/bs.gif) for a race car maybe(for weight, a whole 5 poungs max)...for a street car, removing them does nothing benificial and does not affect the operation of the carbs.... |
TINCAN914 |
Mar 16 2006, 03:28 PM
Ok thanks guy's I feel better now. Now how about my original question. Any suggestions?
Mueller |
Mar 16 2006, 03:29 PM
deal the holes, learn how to weld or buy new rocker panels (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
MattR |
Mar 16 2006, 03:33 PM
Why have lines that connect to nothing? When I took out my FI, I removed the return line and plugged it at the tank. Sure, you could put a bolt in the fuel line after the tunnel, but whats the point? |
Joe Ricard |
Mar 16 2006, 03:37 PM
You can fill weld up holes that big easy.
TINCAN914 |
Mar 16 2006, 03:40 PM
Ok I will live with them for now, and weld fill later before paint.
Thanks |
Eddie Williams |
Mar 16 2006, 03:41 PM
Senior Member Group: Members Posts: 822 Joined: 30-December 02 From: Nederland, TX Member No.: 55 Region Association: None |
Actually the purpose of the charcoal canister/evap system is to hold the fumes form evaporated gasoline and them release them to the intake . This serves to reduce the smell of gasoline in the pasenger compartment and to save the whales or darter snails or whatever.
Allan |
Mar 16 2006, 03:47 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Fill the holes in both the door sill and the panels. I never rivet or screw them on and they stay just fine. Makes it really easy to pull them off every so often to clean.
TINCAN914 |
Mar 16 2006, 04:17 PM
Allan, They don't rattle around? |
Allan |
Mar 16 2006, 04:19 PM
I've done it to 2 cars and never heard them vibrate or rattle. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:17 PM |
