Fuel Pump Noise, Fuel pump making LOUD noise |
MiddleGACruiser |
Mar 17 2006, 07:16 AM
Hobbits? What Hobbits? Group: Members Posts: 115 Joined: 5-September 04 From: Porschenaire, GA Member No.: 2,694 Region Association: None |
This morning when I started the car the fuel pump started making a very loud noise. Otherwise, the car runs/acts normal (for a 33 Y/O).
History: Pump moved to front, under belly pan/cover ~2 years ago. New fuel filter at the same time. Hoses connected according to diagram from Atlanta Amateurs. Quiet operation until this morning. MGC '73 1.7 |
swl |
Mar 17 2006, 07:26 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
not much inside that pump to go noisy. Perhaps your mounting bolts have loosened off?
URY914 |
Mar 17 2006, 07:33 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,446 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I know you've checked this but when the pump and tank are empty, the pump really roars when it is on.
Maybe the filter is clogged and not allowing fuel to get to the pump. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
MiddleGACruiser |
Mar 17 2006, 12:37 PM
I really thought hard about posting this but I just couldn't help it, so here it goes. I didn't check to see if it had gas, I just assumed it did since it runs fine. It just makes a hell of a racket. I think I'll check the mounting bolts. Oh well, I'll check for gas too. But if it's out I'm not adding any since it runs so well without it. Now donning kevlar, let the shooting begin. |
URY914 |
Mar 17 2006, 01:04 PM
Hey I get it, you're using sarcasm in you reply. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) You funny. |
MiddleGACruiser |
Mar 17 2006, 02:31 PM
Hey URY. Thanks for having a sense of humor about my reply. I see you're from Temple Terrace. I grew up in Town n Country, worked for Fred Cox on Florida Ave for a couple of years, and have family all over there.
Rough_Rider |
Mar 17 2006, 04:23 PM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
We'll your not alone. I've a front mounted holley 5psi pump. That thing is loud!!!!! at idle you can hear it above engine noise!
Ironically over the winter i had the entire system drained, firing it up a few time without fuel it was silent. |
Lo-Fi Version | Time is now: 8th May 2024 - 03:37 PM |
