MiddleGACruiser
Mar 17 2006, 07:16 AM
This morning when I started the car the fuel pump started making a very loud noise. Otherwise, the car runs/acts normal (for a 33 Y/O).
History:
Pump moved to front, under belly pan/cover ~2 years ago.
New fuel filter at the same time.
Hoses connected according to diagram from Atlanta Amateurs.
Quiet operation until this morning.
MGC
'73 1.7
swl
Mar 17 2006, 07:26 AM
not much inside that pump to go noisy. Perhaps your mounting bolts have loosened off?
URY914
Mar 17 2006, 07:33 AM
I know you've checked this but when the pump and tank are empty, the pump really roars when it is on.
Maybe the filter is clogged and not allowing fuel to get to the pump.
MiddleGACruiser
Mar 17 2006, 12:37 PM
QUOTE (URY914 @ Mar 17 2006, 08:33 AM) |
I know you've checked this but when the pump and tank are empty, the pump really roars when it is on. Maybe the filter is clogged and not allowing fuel to get to the pump. |
I really thought hard about posting this but I just couldn't help it, so here it goes.
I didn't check to see if it had gas, I just assumed it did since it runs fine. It just makes a hell of a racket. I think I'll check the mounting bolts. Oh well, I'll check for gas too. But if it's out I'm not adding any since it runs so well without it.
Now donning kevlar, let the shooting begin.
URY914
Mar 17 2006, 01:04 PM
QUOTE (MiddleGACruiser @ Mar 17 2006, 10:37 AM) |
QUOTE (URY914 @ Mar 17 2006, 08:33 AM) | I know you've checked this but when the pump and tank are empty, the pump really roars when it is on. Maybe the filter is clogged and not allowing fuel to get to the pump. |
Now donning kevlar, let the shooting begin. |
Hey I get it, you're using sarcasm in you reply.
You funny.
MiddleGACruiser
Mar 17 2006, 02:31 PM
Hey URY. Thanks for having a sense of humor about my reply. I see you're from Temple Terrace. I grew up in Town n Country, worked for Fred Cox on Florida Ave for a couple of years, and have family all over there.
Rough_Rider
Mar 17 2006, 04:23 PM
We'll your not alone. I've a front mounted holley 5psi pump. That thing is loud!!!!! at idle you can hear it above engine noise!
Ironically over the winter i had the entire system drained, firing it up a few time without fuel it was silent.
