How tight to squeez the case, through bolts |
Al Meredith |
Mar 17 2006, 08:02 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
How tight should I torque the RACEWARE case through bolts?
dimitri |
Mar 17 2006, 08:28 PM
dimitri Group: Members Posts: 101 Joined: 16-March 05 From: Cupertino,CA Member No.: 3,769 |
Porsche spec is 40 flbs, you will find even 2 more and the crankshaft
after sitting for a while will take force to brake loose, but ok turning. Dimitri |
Jake Raby |
Mar 17 2006, 09:03 PM
no more than 30 lb/ft....
The only way I go further is if I have the case torqued with the higher value used and re align bore the case... I see cases ruined all the time because guys think more torque is better... Porsche spec on the TIV is 25 lb/ft, not 40. The torque value is as dependant upon the case as the fastener. Don't go past 30. |
Cap'n Krusty |
Try 23.72 ft/lbs, NOT 40. You'll increase the bearing crush and increase the bearing wear dangerously. BAD MOVE! IMO, the torque spec remains 24 ft/lbs, Raceware, stock studs, or whatever. The Cap'n |
Al Meredith |
Mar 18 2006, 07:45 AM
Thanks to all 25/30 it is, Jake I'm assembling my 2056 this weekend, Thanks Al
Jake Raby |
Mar 18 2006, 08:12 AM
I figured you were...
Have fun.. |
dimitri |
Mar 18 2006, 11:58 AM
I stand corrected, 25 it is. Should not have trusted my memory!
Dimitri |
Lo-Fi Version | Time is now: 9th May 2024 - 11:28 AM |
