Al Meredith
Mar 17 2006, 08:02 PM
How tight should I torque the RACEWARE case through bolts?
dimitri
Mar 17 2006, 08:28 PM
Porsche spec is 40 flbs, you will find even 2 more and the crankshaft
after sitting for a while will take force to brake loose, but ok turning.
Dimitri
Jake Raby
Mar 17 2006, 09:03 PM
no more than 30 lb/ft....
The only way I go further is if I have the case torqued with the higher value used and re align bore the case...
I see cases ruined all the time because guys think more torque is better...
Porsche spec on the TIV is 25 lb/ft, not 40. The torque value is as dependant upon the case as the fastener.
Don't go past 30.
Cap'n Krusty
QUOTE (dimitri @ Mar 17 2006, 06:28 PM) |
Porsche spec is 40 flbs, you will find even 2 more and the crankshaft after sitting for a while will take force to brake loose, but ok turning. Dimitri |
Try 23.72 ft/lbs, NOT 40. You'll increase the bearing crush and increase the bearing wear dangerously. BAD MOVE! IMO, the torque spec remains 24 ft/lbs, Raceware, stock studs, or whatever. The Cap'n
Al Meredith
Mar 18 2006, 07:45 AM
Thanks to all 25/30 it is, Jake I'm assembling my 2056 this weekend, Thanks Al
Jake Raby
Mar 18 2006, 08:12 AM
I figured you were...
Have fun..
dimitri
Mar 18 2006, 11:58 AM
I stand corrected, 25 it is. Should not have trusted my memory!
Dimitri
