ooohhhhhh kay |
ooohhhhhh kay |
bd1308 |
Mar 18 2006, 02:59 AM
needed fuel, went to pull the release and snap!
the sheath (plastic) broke. I need one REALLY REALLY badly. please if you have one, pm me or if you know my addy just send it. Otto, I'm getting a check out to you on monday. Thx btw b |
Andyrew |
Mar 18 2006, 04:49 AM
wait..
what do you need? |
sj914 |
Mar 18 2006, 05:00 AM
I think he needs the front trunk release cable sheath.
bd1308 |
Mar 18 2006, 09:20 AM
yes I need the cable sheath....im thinking that I can just slip off the old and slip in the new.
but i really really really need it. b |
Mar 18 2006, 10:06 AM
Britt,
Any bolen (sheath) will work. Plastic tubing from a hardware store will work. The key is the sheath has to remain stationary while the cable is being pulled, the end where it fits into the handle is a special shape.. If it is just broken and it is flexing, you could use duct tape, or you could put a plastic tube over the broken area.. The key is to keep the outer sheath still, and keep it from flexing... Get it open again, and fix it..or next time you may have to take off the bumper to get the trunk open. Rich |
bd1308 |
Mar 18 2006, 10:12 AM
yeah at speedway in bone fuch ohio at 1:30 I had to take my bumper off to fill up, only after taking the barbarian approach and completly denting up the front trunk. i *DO* know where i'm putting my good stuff now though.
bumper off, fill up, bumper on....only 30 minutes (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) b |
rhodyguy |
Mar 18 2006, 10:23 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
has the sheath slid through the little clamp on the latch mechanisim? the sheath needs to be secured. mine had slid through and was restricting the release action. degrease the area, make sure the plastic is positioned correctly, and put a little dab of 2 part epoxy on the leading edge of the sheath at the clamp. mine has held now for 9 months.
k Attached image(s) |
jim912928 |
Mar 18 2006, 10:25 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Britt,
The plastic sheath sucks...don't buy one! If the cable is ok...take that and the old sheath down to any gocart shop and have them cut to length a brake/clutch cable. Then pull out the braided cable and insert the 914 cable into the cart sheath. This will cost you 10 bucks and you'll be able to open your trunk with 1 finger pulls! |
bd1308 |
Mar 18 2006, 10:28 AM
yeah about that thing (im sure its why im in my pickle)...
some ham-handed bastard (im sorry this DAPO thing pisses me off) crunched the plastic sheath against a washer and a philips head screw and something that allows the cable to slide through the contraption whilst preventing the sheath from moving.... it isnt factory im certain, bc the screw for accessing that is under the mechanism and with a t4 in the front trunk anyway, its hard to get in there with screwdrivers and such.... b |
bd1308 |
Mar 18 2006, 10:29 AM
gokart shop (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) ive never seen one....I was thinking about a FLAPS choke cable or something.... i'll look for gokart shops though...i think a real sheath is the way to go. b |
jim912928 |
Mar 18 2006, 10:33 AM
Britt, motorcycle shop, ATV shop...lawnmower shop can do the same thing...anybody that can make cables to length. They can also then put on metal ends that won't slip. The plastic sheath that is original is prone to binding (many squirt lub into it over time) and cracking. They almost always end up hard to open. The setup I outlined works very easy and is similiar to how engman did his rear trunk kit (which you can also open with one finger).
bd1308 |
Mar 18 2006, 11:22 AM
bicycle shop (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
i'll look around though....i still have 3/4 tank left b4 i have to take the bumper off again.... b |
Mar 18 2006, 11:35 AM
Bicycle shop, a high end one will cut bolen sheath to length.
Get one that has the outer is rubber,nylon...then a metal spiral tube...then a teflon inner housing... Campagnolia (I forget how to spell it,,,its a bicycle manufacturer) make a really slick, slippery sheath. Look up bolen cable on google to get the engineering understanding of how it works, and the principles..that way you will understand that the bolen/sheath must stay still, not flex, and both ends must be held firmly in place. The more you spend on the sheath, the happier you will be. Rich |
Dave Bell |
Mar 18 2006, 11:59 AM
Member Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None |
I think I found something at Home Depot to replace both the cable and the sheath.... cable is braided stainless steel now and works just fine. My memory fails me but I think I reused the hand cable end piece on the new cable by grinding a groove in it, placing the new cable in the groove and welding a tad of carbon steel back over it ... has worked fine for years.
.... and yes it was after it broke when I needed gas and had to do the bumper off, gas, bumper on thing... not fun - Dave |
scottb |
Mar 18 2006, 01:32 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
hehehehe...... he said it... |
Lo-Fi Version | Time is now: 9th May 2024 - 06:58 AM |
