My car hates me..., Clutch advice anyone? |
pib |
Mar 18 2006, 12:52 PM
Re Member Group: Members Posts: 116 Joined: 5-February 06 From: Monterey, CA Member No.: 5,530 |
So at 1:00 am this morning, I'm leaving work, hop in the little red teener, put it in reverse, and snap the clutch cable. I hear it's not un-common. Still drove it home...no traffic at all, and only had to stop once for a red light.
So I'm wondering: 1. What's the best cable to get, and where? 2. It seems an awful big coincidence that this happens the day after I install a new shift lever assembly (thanks again for the help Mueller! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) ) Is it possible that removing and replacing a shift assembly would affect the clutch cable? I looked at the tube while the shifter was out, and it wasn't bent or otherwise distressed. I installed the new assembly, and adjusted it per the trusty Haynes manual, and it shifted great, until the snap. 3. I've read what the manual says about replacing and adjusting a clutch cable, is there any other advice for a first-timer? Anything else I should check while it's apart? Thanks, Pete |
1970 Neun vierzehn |
Mar 18 2006, 03:58 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Pete,
I broke a clutch cable a lo-o-o-ng time ago, replaced it with EOM and have not had to r&r it thereafter. I'm assuming that there is a small wheel at the rear of the transmission that your clutch cable is routed around. When I first got the car, I kept that wheel assembly "squeaky" clean, keeping the wheel contour that the cable passed around spotless. After that first clutch cable failure, I've kept the cable/wheel assemply liberally covered in white grease. It's been 20+ years since that cable has been changed, and I no longer worry about it. BTW, make sure there aren't any sharp bends in the cable as it wends its way back into the passenger compartment. |
Lo-Fi Version | Time is now: 30th May 2024 - 12:23 AM |
