9"x17" rear wheels - need help |
hwhelchel |
Mar 18 2006, 08:18 PM
Newbie Group: Members Posts: 3 Joined: 4-July 04 From: Potomac Falls, VA Member No.: 2,297 |
After 3 years of collecting parts (and $$$) I am ready to start the body work for my 914-6 conversion. I plan to run 9”x17” 255 stock 993 wheels on the rear with either custom flares or SC flares. My question for the experts is this, will I have to run spacers to keep the tires from rubbing on the inside and how much will the fender have to come out to have enough room for the tires. Searched posts but could not find info.
d914 |
Mar 18 2006, 08:20 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
what offset or et?? more than likey spacers in the 35-54mm range.
et 52?? |
Mueller |
Mar 18 2006, 08:29 PM
those rims should have a 55mm or 65mm offset I think....you'll need at least 2" spacers
hwhelchel |
Mar 18 2006, 09:08 PM
They are 55 offset...any idea how much the fenders will have to come out?
Mueller |
Mar 18 2006, 10:42 PM
I am running 17x7's with 205's under stock fenders(35mm offset), I have about 3/8" between the tire and the fender, and about 3/8" to 1/2" between the tire and the trunk wall....so, I'd say at a minimum, you'll need to come out 2" |
Joe Bob |
Mar 18 2006, 11:22 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
If they are late offset, most likely 1 inch up front and 2 in the rear.
If you haven't bought them yet....I have a set of spacers and 16x7.5 and 16x9 964 wheels and tires just sitting.....new Kumhos. Whels are pwoder coated semi-flat black. |
Andyrew |
Mar 19 2006, 03:58 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
fenders would have to come out 2+ inches.
consider that a 7in rim can fit barely in stock fenders. a 9in rim would need 2 more inches. Andrew |
ajracer |
Mar 19 2006, 08:53 PM
Member Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 |
Greetings:
Let me see if I can help you on this one; from memory. My 1974 has the following five bolt components. Fronts 17" X 7" ROH rims with 205/50/17 tires AND 1" spacers (I believe there is actually room for bigger tires, no flares; BUT used a 944 front hub) Rears 17" X 8.5" ROH rims with 255/50/17 tires AND 1" spacers AND 9" GT Flares. (This is a tight fit, 0.25" inside/outside for clearance.) These Rims were from later 911/993 which are 55mm offsets From my experience be EXACT on what size spacers are needed before you purchase any BECAUSE I calculated and bought a large 2" plus on the rear before I realized a much smaller would do the job. I idea in my mind is to get the minimum clearance on the inside and then work your way outside to determine what size tires flare combination will work the best. Trust this helps. Allan PS These spacers I believe were actaully 28mm The above wheels were my set-up ones but from here I will be moving to better sizes and profile to particiate in some AX or solo events. |
Mueller |
Mar 19 2006, 11:46 PM
Allan, without the backspace or offset numbers for your rims, those specs get kinda lost..... |
joea9146 |
Mar 20 2006, 05:14 AM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I am running 996 wheels 9x17 on the rear with 255x40x17 Toyo R1A , I am running Fiberglass GT flares.... the outside spacing is close with 2 inch spacers 1 3/4 spacers would work better if you could find them.
hwhelchel |
Mar 20 2006, 10:05 PM
Thanks everyone, I have my work cut out for me....Now if I could just find a good body shop in Northern VA...
Lo-Fi Version | Time is now: 20th May 2024 - 03:18 AM |
