Reasonably priced 4 lug to 4 lug spacers.... |
Joe Bob |
Mar 18 2006, 11:28 PM
Anyone have a line on 4 lug to 4 lug spacers? VW/914 pattern?
Aaron Cox |
Mar 18 2006, 11:29 PM
guy on ebay will make you ANY spacer or adapter....
you want bolt on adapter or stud thru spacers? hubcentric? |
Joe Bob |
Mar 19 2006, 08:03 AM
The fronts on BAD TUB rub on the inside at full lock...so I need to space it out a bit. I could have haves an 8 up front but went with 7s....that's what I get listening to free advice.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Tom Perso |
Mar 19 2006, 08:30 AM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
I'll sell you an assload of washers for $50 a side. Custom made.
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Sounds like a machine shop visit to me. It's just a spacer and the VW wheels aren't hub-centric or anything crazy. Just need longer studs. Tom |
URY914 |
Mar 19 2006, 09:02 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,389 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Get some 1/4" aluminum material and drill some holes. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Joe Bob |
Mar 19 2006, 09:11 AM
Longer studs....for internal style stockers......good luck finding them.
Mar 19 2006, 10:03 AM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
PepBoys sell 1/4, 5/16, and 3/8 spacers.
I think I get the 6 lug one and have to drill two holes to make it work... Very cheap also. Rich |
Joe Bob |
Mar 19 2006, 10:16 AM
I need about an inch....
Mar 19 2006, 10:21 AM
Way to easy...
Lots of quick and simple jokes flew into my head... Seriously, Either convince someone with a lathe to make you some (Mike) or the guy on ebay. I had them stacked up on my racecar...over an inch...but on a street car, I would say get a single piece one. I had studs also, so it was easy to change the size of the spacers... Rich |
Joe Bob |
Mar 19 2006, 10:25 AM
I could always press in long studs and do the stack thing. I think the front end is a Karmann Ghia disc brake unit.
Guess I'll cruise the VW forums and look and see what's out there...... |
Tom Perso |
Mar 19 2006, 10:43 AM
Hey Z,
You can find VW Passat or Audi A4 bolts that will work just fine. In fact, I used them over the stock Bug bolts. Go order some online, I know the Audi guys are always needing longer bolts to fit spacers and their bling rims. Those newer bolts are MUCH higher quality than any Bugpack POS. Tom |
rhodyguy |
Mar 19 2006, 10:58 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
go buy a hotvw mag. poop pot full of vendors. somebody will have what you need.
k |
Lo-Fi Version | Time is now: 5th May 2024 - 05:12 AM |
