WANTED: more oversteer, suspension settings? |
motorpants |
Mar 19 2006, 05:13 PM
Newbie Group: Members Posts: 14 Joined: 2-February 06 From: toronto canada Member No.: 5,516 |
I am in the early stages of setting up a 3.0 914 for a road course (track settings) - I have limited seat time but most of it has been in a 911
I would like to get a little more (some) rotation after the turn-in. As is, the car just ploughs (like a front engine understeer) on the edge of adhesion I am running 8 inch rubber all around, turbo tie rods, stockish springs outside rear compression too much? I just got the car and already understand the attraction - I did a donut skidpad drill in a parking lot and no matter what combo of throttle and lift I could'nt break the rears Idears? Josh |
SirAndy |
Mar 19 2006, 05:17 PM
Resident German Group: Admin Posts: 41,642 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
got swaybars? if so, back off the front bar (move it towards the *front* of the car). if it's already full soft or if you don't have a front swaybar, get heavier springs for the rear. until then, try to drop the tirepressure in the front and bump it up a bit in the rear ... simple rule: - if the front is lose, tighten the rear - if the rear is lose, tighten the front (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) Andy PS: all this, of course, only makes any sense if the car is aligned correctly and corner balanced first ... |
Andyrew |
Mar 19 2006, 05:23 PM
Stockish springs?
Whatever their lb rate, up it by 40. Your running a six? 165 progressives or 180's will get you good turn in. And if you dont have sway bars.. put on on front and rear. Adjustable would be best... Tighter the rear, more turn in response Too tight, it'll come around on you too much. too loose, plowage (as you know well) If you have a front bar, and no rear bar, 180's would be good. If you have a big front bar, 200's would be good, and adjust the front bar where you like it. (big bars are adjustable) And.. what andy says works too.. Make sure you got good shocks.. |
motorpants |
Mar 19 2006, 05:28 PM
God I love this place
can't wait to do more testing to get it right thanks a bunch |
Lo-Fi Version | Time is now: 18th May 2024 - 12:49 PM |
