15x7", Wheel question |
Mar 21 2006, 04:34 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
nope ... i put in my 100mm studs without taking the hub off ... gotta rotate the hub as only one hole clears the trailing arm. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
fiid |
Mar 21 2006, 04:50 PM
I have 15x7 cookies on my car with Kuhmo Ecsta 712 ((IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) - slippy tires) 205x15x50s on them. I had to do a bunch of fender rolling to get those under the backside of the car.
Big thanks to SynthesisDV for selling me the wheels tho (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Aaron Cox |
Mar 21 2006, 05:32 PM
ahah! i knew it.... what did you use to press em in? |
Mar 21 2006, 07:33 PM
no press ... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) slide in until splines line up, slide piece of pipe over the stud, then a big washer, then thread on a old open lug nut. it'll pull the stud right into place! i used a little bit of lock-tight (sp?) on the splines, just to be sure ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
Aaron Cox |
Mar 21 2006, 07:52 PM
very smart andy!
914Timo |
Mar 22 2006, 01:28 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
This is my 914 with 7x15 911 R Fuchs and 205/50/15 tires. Stock body. No fender rolling. No spacer in front, but about 1/2 inch spacers in rear. Attached image(s) |
mskala |
Mar 22 2006, 12:18 PM
I did not know that. Could come in handy some day. |
Aaron Cox |
Mar 22 2006, 12:20 PM
where does one even find 911R wheels? ive seen a set locally.... but i mean, how many 911R's were there?????
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) |
campbellcj |
Mar 22 2006, 11:35 PM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I've seen 911R wheels pop up from time to time on Pelican and Rennlist classifieds. They cost as much as some reasonably nice 914's...
I went the rolling and pulling route on my rear fenders and can fit 15x7's or 16x7's with 205 Hoosiers (wide). If I ever repaint the car I'll probably do the 'slicing' trick to get enough room to squeeze 225's. Most of the VARA cars are set up this way - 225/50 Kumhos on 15x7 Fuchs with a stock-appearing body. |
sixnotfour |
Mar 22 2006, 11:52 PM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Porcharu |
Mar 23 2006, 02:25 AM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
I was thinking about some custom wheels (probably some steel ones.) I'm just looking for the correct offset. |
Aaron Cox |
Mar 23 2006, 10:43 AM
thats pretty cool! take a set of deep sixes and add an inch (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
mskala |
Mar 23 2006, 10:55 AM
There were only 21 911R cars made. However, I think I remember the batch of wheels being about 200 sets. |
pete-stevers |
Mar 23 2006, 02:13 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
my brother 15x7s on his car with 205s on it ...it required a bit of fender rolling , but they fit ok and rub slightly very ocasionally....
Porcharu |
Mar 23 2006, 03:44 PM
Very nice! I wish I could find a set that I could afford. |
Lo-Fi Version | Time is now: 28th April 2024 - 05:52 PM |
