Do I run a ballast resistor? |
Mockmaw |
Sep 12 2003, 10:50 AM
Member Group: Members Posts: 163 Joined: 18-March 03 From: Berkeley/San Diego, CA Member No.: 438 |
Okay, I'm running in circles confusing myself.
I'm running a Mallory Unilite distributor and a new bosch blue coil. No C/D. No MSD. On the front of my blue coil it says "Not Internally Resisted".. does this mean I need to run a ballast resistor? I didn't know they even made blue coils that weren't internally resisted. Thoughts? |
Mockmaw |
Sep 12 2003, 11:30 AM
Err.. scratch that.. it says "Without Resistance"
MarkV |
Sep 12 2003, 11:36 AM
This is what I used for a Pertronix Flame Thrower coil:
The next step is to determine the resistance in the primary ignition. Label the wires attached to the coil terminals and note their appropriate location. Make sure that the ignition switch is off and disconnect all wires from the coil. Adjust your meter to the lowest ? ohm scale. If you are using an analog style meter make sure to zero the needle. Measure from the negative terminal to the positive terminal. Write your measurement down. Now the maximum system amperage can be determined, divide your voltage measurement by your coil resistance measurement. This will give you the system current or amperage. Four cylinder engines should not exceed 4 amps. Six and eight cylinder engines should not exceed 8.5 amps. If the total amperage in your system is higher than the amount recommended for your application, you should install a ballast resistor. Example Voltage 12 Resistance 1.5 12 / 1.5 = 8 Total amperage 8 |
Joseph Mills |
Sep 12 2003, 12:38 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
QUOTE(Mockmaw @ Sep 12 2003, 10:50 AM) I'm running a Mallory Unilite distributor and a new bosch blue coil. No C/D. No MSD. On the front of my blue coil it says "Not Internally Resisted".. does this mean I need to run a ballast resistor? I didn't know they even made blue coils that weren't internally resisted. I just went through this also. In my case, I'm running a HYFIRE CD box, so don't need a ballast - and my Blue coil has a built in resistor (Brad pointed this out to me originally). However, in your case, it sounds like you SHOULD use a resistor. Mallory has a tech number you can call and get it straight from them. The number is 1-775-882-6600. |
Lo-Fi Version | Time is now: 20th May 2024 - 01:44 AM |
