Will this engine dolly work with Type IV motors?, Says for "Beetle Style Engines". |
Charles Deutsch |
Sep 12 2003, 05:32 PM
Unregistered |
Anyone have one of these for rolling around their T-4 motor?
ChrisFoley |
Sep 12 2003, 05:40 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
looks a bit cheesy to me (IMG:style_emoticons/default/barf.gif)
Buy 4 casters and screw them to a board. Add a couple of small pieces of wood to stabilize the engine. Done for less than half the price. (IMG:style_emoticons/default/smash.gif) |
JeffBowlsby |
Sep 12 2003, 05:44 PM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Can you say...furniture dolly?
Mike D. |
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I have one. got it a pamona a few years back. It only fits type I engines...
-Mike D. |
sj914 |
Sep 13 2003, 02:26 AM
It doesn't look very sturdy with just having three sides. A wooden furniture dolly would probably be cheaper and safer.
ArtechnikA |
Sep 13 2003, 05:39 AM
QUOTE(bowlsby @ Sep 12 2003, 03:44 PM) Can you say...furniture dolly? just curious about this : " 914 Trivia The 914 was the first production Porsche to have rear coil-over shock absorbers and semi-trailing arm rear suspension. The mid-engine configuration precluded the use of the traditional torsion bar suspension used on earlier Porsches. " this statement is AFAIK correct with regard to the semi-trailing arms. but if the point is coilover vs torsion bars in back - go have a look at a 904 ... (no semi-trailing arms in back, tho - wishbones and radius rods...). also mid-engined. |
URY914 |
Sep 13 2003, 06:16 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I think the word "production" may be the key. Was the 904 considered production?
Paul |
ArtechnikA |
Sep 13 2003, 06:35 AM
QUOTE(URY914 @ Sep 13 2003, 04:16 AM) I think the word "production" may be the key. Was the 904 considered production? yup. they made about 135, available through the dealer. many were sold into racing but there were more than a few licensed for (and driven on) the street. |
URY914 |
Sep 13 2003, 06:38 AM
I know that there were street cars but maybe they didn't consider them "production" Just a thought.
By the way I flipped my oil cooler over so it doesn't drain back. Thanks for the tip. Paul |
fiid |
Sep 13 2003, 06:45 AM
QUOTE(Racer Chris @ Sep 12 2003, 03:40 PM) Buy 4 casters and screw them to a board. Add a couple of small pieces of wood to stabilize the engine. Done for less than half the price. (IMG:style_emoticons/default/smash.gif) I screwed 4 castors to a fork truck pallet. This works very well and it can actually (although not advisable) support the weight of the car. It does make nasty cracking sounds though. Fiid. |
JeffBowlsby |
Sep 13 2003, 08:17 AM
QUOTE this statement is AFAIK correct with regard to the semi-trailing arms. but if the point is coilover vs torsion bars in back - go have a look at a 904 Taken from Excellence Was Expected...is the word of Ludwigsen being challenged...? its OK...I have found other exaggerations and semi-truths... |
ArtechnikA |
Sep 13 2003, 08:38 AM
QUOTE(bowlsby @ Sep 13 2003, 06:17 AM) Taken from Excellence Was Expected...is the word of Ludwigsen being challenged...? its OK...I have found other exaggerations and semi-truths... it's NOT EASY making any book, and a big "comprehensive" and "authoritative" volume about a carmaker that didn't even keep records a lot of the time is a substantial challenge... i have the first edition Excellence Was Expected, and the new & revised edition is on my Christmas list -- if i can exercise enough restraint to keep from just going to buy it before then ! at least this isn't flat-out wrong technically -- there was a statement in Frere's '911 Story' regarding the aluminum suspension cross member and front geometry of the I-Series and later cars that had be going off in a totally wrong direction for a while. turns out the crossmember is identical in all the important dimensions and the suspension geometry change was made to the tub itself... |
EdwardBlume |
Sep 13 2003, 09:55 AM
I have one, and its a worthless piece of crap. It's too high, it doesn fit nicely underneath the case, and fully loaded, those small wheels don't move very easily. A jackstand and a friend works better.
I think the concept could be done for a 914 engine but it would have to take more thought. (IMG:style_emoticons/default/blink.gif) |
mharrison |
Sep 13 2003, 05:26 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
Any mechanical engineers or just excellent welders want a project?
How about making a frame that fits the base of the engine well. Attach this to a swivel that will fit the top of a floor jack? Or maybe just build this on a scissor jack type device like a motorcycle jack? We've all R&R'd these engines with a floor jack and it's not too hard, but wouldn't something better be awesome? Make all for casters to rotate as well as adding a lock and/or brake to them. The scissor jack Idea would make a good stand to store one on as well. It just wouldn't have the heighth of a standard stand. I wouldn't think this would be too difficult, but I'm not a welder by any strech of the imagination. (I can weld it if it's broken, but it won't be pretty. I am the king of Gorilla welds!) Just a thought. |
MarkV |
Sep 13 2003, 05:49 PM
This place VW Alleysells a rack that goes on a floor jack. I don't think it is big enough for a Type4 though.
Lo-Fi Version | Time is now: 15th May 2024 - 05:16 PM |
