Fuel injectors, Flow test |
Ferdinand |
Mar 26 2006, 12:06 AM
Newbie Group: Members Posts: 11 Joined: 4-January 06 From: Oakland, CA Member No.: 5,369 |
Does anyone know of a shop in the San Francisco Bay Area that flow tests and cleans fuel injectors? Thanks
mightyohm |
Mar 26 2006, 12:17 AM
No, but I just had a dozen or so injectors cleaned and tested at Cruzin Performance for $12 ea. The process took about 2 weeks but you can't beat the price, and they come with new o rings (both small and large!!).
http://www.cruzinperformance.com/ |
zymurgist |
Mar 26 2006, 07:12 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I'd like to second the recommendation for Cruzin Performance. I sent 4 injectors to Rich... 3 of the 4 2.0 injectors were stuck closed. He fixed and flow tested them and I got them back pretty quick.
BMartin914 |
Mar 26 2006, 12:12 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
I recently sent 6 280zx injectors out to witchhunter performance (www.witchhunter.com) in Bothell, WA for $15 each. They cleaned, flowtested and replaced the seals on each injector. Sent them out Wed., they got them Fri., I had them back on Mon. Shipping is free with 6 or more injectors - $10 for 5 or fewer.
Rotary'14 |
Mar 26 2006, 02:14 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Actually shipping is free for 4 injectors on up. $10 for 3 or less. I just had 4 sent back from them as well too. -Robert |
BMartin914 |
Mar 26 2006, 02:55 PM
My bad. Got confused. Even better for those of us in the 4 cylinder crowd. They do good work don't they? I noticed a significant improvement. |
yarin |
Mar 26 2006, 08:11 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Add me to the list of satisfied customers of CruzinPerformance. They give post your results on the web and send u a link. Excellent service and turn around time. great price too.
Ferdinand |
Mar 26 2006, 09:37 PM
Thanks a million!$$$$$$$$$$$$$$$$$$$$
blitZ |
Mar 27 2006, 06:21 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Partial (IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) ...
I think I iwll try these injector cleaning services soon. Any trick to getting the injectors out? I did a search didn't see any notes. |
yarin |
Mar 27 2006, 08:31 AM
Here is the data from my injector service.
Removing the injectors is pretty simple. Pull the connector, remove the fuel clamp, remove fuel hose, remove nut on injector bracket. Injector will fall out. Of course you might want to drain the fuel out of the system first. You could try disconnecting the supply side after the fuel pump. Good luck. Do NOT do this in a closed unventilated garage. Make sure any electrical spark sources are shut down (ie: compressor, furnace, garage door opener, etc). Attached image(s) |
Lo-Fi Version | Time is now: 29th May 2024 - 11:00 PM |
