Ferdinand
Mar 26 2006, 12:06 AM
Does anyone know of a shop in the San Francisco Bay Area that flow tests and cleans fuel injectors? Thanks
mightyohm
Mar 26 2006, 12:17 AM
No, but I just had a dozen or so injectors cleaned and tested at Cruzin Performance for $12 ea. The process took about 2 weeks but you can't beat the price, and they come with new o rings (both small and large!!).
http://www.cruzinperformance.com/
zymurgist
Mar 26 2006, 07:12 AM
I'd like to second the recommendation for Cruzin Performance. I sent 4 injectors to Rich... 3 of the 4 2.0 injectors were stuck closed. He fixed and flow tested them and I got them back pretty quick.
BMartin914
Mar 26 2006, 12:12 PM
I recently sent 6 280zx injectors out to witchhunter performance (www.witchhunter.com) in Bothell, WA for $15 each. They cleaned, flowtested and replaced the seals on each injector. Sent them out Wed., they got them Fri., I had them back on Mon. Shipping is free with 6 or more injectors - $10 for 5 or fewer.
Rotary'14
Mar 26 2006, 02:14 PM
QUOTE |
Shipping is free with 6 or more injectors - $10 for 5 or fewer. |
Actually shipping is free for 4 injectors on up. $10 for 3 or less.
I just had 4 sent back from them as well too.
-Robert
BMartin914
Mar 26 2006, 02:55 PM
QUOTE (Rotary'14 @ Mar 26 2006, 12:14 PM) |
QUOTE | Shipping is free with 6 or more injectors - $10 for 5 or fewer. |
Actually shipping is free for 4 injectors on up. $10 for 3 or less. I just had 4 sent back from them as well too.
-Robert |
My bad. Got confused. Even better for those of us in the 4 cylinder crowd.
They do good work don't they? I noticed a significant improvement.
yarin
Mar 26 2006, 08:11 PM
Add me to the list of satisfied customers of CruzinPerformance. They give post your results on the web and send u a link. Excellent service and turn around time. great price too.
Ferdinand
Mar 26 2006, 09:37 PM
Thanks a million!$$$$$$$$$$$$$$$$$$$$
blitZ
Mar 27 2006, 06:21 AM
Partial
I think I iwll try these injector cleaning services soon. Any trick to getting the injectors out? I did a search didn't see any notes.
yarin
Mar 27 2006, 08:31 AM
Here is the data from my injector service.
Removing the injectors is pretty simple. Pull the connector, remove the fuel clamp, remove fuel hose, remove nut on injector bracket. Injector will fall out.
Of course you might want to drain the fuel out of the system first. You could try disconnecting the supply side after the fuel pump.
Good luck. Do NOT do this in a closed unventilated garage. Make sure any electrical spark sources are shut down (ie: compressor, furnace, garage door opener, etc).
