How do i adjust my shifter?, 901 Side Shifter |
dlo914 |
Mar 26 2006, 02:01 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
(IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) im getting a slight grind noise when i shift into 2nd gear. The other gears are fine. Well actually everything was fine until my friend said that the shifting needed some adjustment. And now 2nd is harsh to get into. I check PP for a tech article on how to adjust the shifter, but i came up w/ nothing. So yea need some tips on how to adjust the shifter. Thanks in advance gang.
olav |
Mar 26 2006, 02:08 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Could be that your second gear sychro is going south. That's what happened to me. Grinding going into second no matter what adjustments I made. Once I put in a new sychcro everything was smooth again. |
Aaron Cox |
Mar 26 2006, 02:11 PM
dlo914 |
but it was fine before my friend adjusted the shifter. |
dlo914 |
Mar 26 2006, 02:12 PM
you mean see if there's slack on the clutch cable? at the transmission end where it loops over that circular disk? |
rhodyguy |
Mar 26 2006, 02:18 PM
where is james' (yellowbeard) adj procedure? did your friend remove the base of the shifter from the front bar? how does the freeplay (fore and aft) compare while in 2nd & 3rd? how tight (sideways) is 2nd to the 1&R lock out plate?
k |
dlo914 |
Mar 26 2006, 02:19 PM
i remember watching my friend take off this one cover plate underneath the center cushion and loosening up this one 13mm bolt right beneath the shifter to adjust the shifter. But from there im clueless as to which direction i adjust the shift rod.
Aaron Cox |
Mar 26 2006, 02:21 PM
its described in your haynesmanual....
if it was fine, why did he adjust it? |
Brando |
Mar 26 2006, 02:30 PM
He thought it was a 915 shmifter... Confused it with a Fiat... Was wondering why Second was forward, was trying to make it straight back... |
rhodyguy |
Mar 26 2006, 02:31 PM
please go try your shifter and address the questions i asked. it could be very simple.
k |
dlo914 |
Mar 26 2006, 02:41 PM
he didnt think it was fine. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
dlo914 |
Mar 26 2006, 02:43 PM
o wells i managed to do it by feel and look. And managed to get it shift pretty well just have to go into 2nd slowly.
olav |
Mar 26 2006, 03:10 PM
Sounds like the sychro is going going ... |
dlo914 |
Mar 26 2006, 03:24 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 03:10 PM |
