How to Powdercoat Cookie cutters, with spray paint |
Andyrew |
Sep 12 2003, 09:53 PM
I decided that for my track wheels I would try your "Autozone" paint, its the duply (sp?) wheel paint in "chrome", but its more of a powder.. really cool
Anyways, why dont I do a how to (IMG:style_emoticons/default/laugh.gif) Assuming you have some piece of junk wheels you want to make look decent, here are some steps.. Take your wheels and Chemically strip them, Make sure you sand down the wheels really well, takeing all the high spots, I used 600 grit, then 1000 grit on the lip. Attached image(s) |
Andyrew |
Sep 12 2003, 09:55 PM
Next mask them, masking tape works good (what a concept! (IMG:style_emoticons/default/ohmy.gif) )
Andyrew |
Sep 12 2003, 09:56 PM
A close up of the affect of the spray paint, looks alot like a metalic flake..
Andyrew |
Sep 12 2003, 09:58 PM
With the masking tape on.
Remove the tape when it is dry enough to touch the tape, and make sure not to touch the wheels, this way whatever is pulled up when you remove the tape has time to settle before it completely dries. Attached image(s) |
Andyrew |
Sep 12 2003, 09:59 PM
mo picks
Andyrew |
better light.
Walla!! next is clearcoating.. Attached image(s) |
vortrex |
Sep 12 2003, 10:04 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
looks pretty good, will be interesting to see how it holds up.
redshift |
Sep 12 2003, 10:05 PM
Nice lookin.. I may do a quicky job on a set of Fuchs Sunday.
M |
p914 |
Sep 12 2003, 10:54 PM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
Mediablast gives better results than chemical stripping. The rest looks good. Keep us posted on how they last. Link below shows my Fuchs project. that I got from Steve Thacker on eBay. The wheels were straight and true, just in need of blasting and polishing.
http://www.villagephotos.com/pubbrowse.asp...selected=252977 |
Andyrew |
Sep 12 2003, 11:21 PM
The Cookie cutters are just track wheels, I bought chemicals to strip it with for 5 bucks, and the paint for another 10 (with clearcoat).. not a bad look for 15 bucks.
I think they will work very well, and they look good. I have my polished Fuch's for my driving around town in. (IMG:http://www.914world.com/bbs2/uploads/post-2-1063154991.jpg) Nice job on the polishing though! |
Korijo |
Sep 13 2003, 12:44 AM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
I dont think you're supposed to clear coat that type of paint. Read the label...
ArtechnikA |
Sep 13 2003, 05:46 AM
QUOTE(Andyrew @ Sep 12 2003, 07:59 PM) better light. you painted over the rubber valve stem ? you painted over the stick-on tire weights? i think you'll have an interesting time getting the paint to match next time you have new tires balanced ... |
dan10101 |
Sep 13 2003, 06:49 AM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
QUOTE I dont think you're supposed to clear coat that type of paint. Read the label... I read the label, and I tested it. QUOTE you painted over the rubber valve stem ? No, I duck taped it off, didnt remove it yet. QUOTE you painted over the stick-on tire weights? There track wheels, I dont care.. I just needed some color Andrew |
URY914 |
Sep 13 2003, 06:54 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Now you to be careful you don't get any WD40 on them. (IMG:style_emoticons/default/cool_shades.gif)
p914 |
Sep 13 2003, 09:32 AM
How did that stripper work for you? Was there previous paint on the wheels? I bet sanding was tough with all the terrain on the wheels. Looks good for a set track wheels. Duplicolor is good paint for a number of jobs. The textured stuff recently put out is a nice touch.
Lo-Fi Version | Time is now: 15th May 2024 - 04:46 AM |
