Impeller marks for valve adjust |
jsf322 |
Mar 26 2006, 04:14 PM
Member Group: Members Posts: 83 Joined: 1-December 05 From: Baldwin, New York Member No.: 5,220 |
I was looking over my '76 2.0 getting ready to attempt my first valve adjustment and found marks different than what I had read. I found a yellow dot on the fan when the distributor rotor was pointing towards 7 o'clock and a notch in the flywheel through the opening on the bottom of the transmission. Is this cylinder #2 at TDC. I found another mark on one of the impeller blades when the distributor rotor was pointing towards the notch in the distributor housing. I assume this is the mark for cylinder #1 TDC but I am not sure. It did not look like what I expected. It was just a yellow line on the blade. I have attached some photos.
jsf322 |
Mar 26 2006, 04:16 PM
The picture above was with the distributor pointing towards the #2 wire tower. The picture below is the mark with the distributor pointing towards the notch in the housing which seems to go with the #1 wire tower.
echocanyons |
Mar 26 2006, 06:52 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
BMartin914 |
Mar 26 2006, 07:01 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
The notches you need to look for are on the opposite side of the impeller than the painted marks in your pics - and they are actual notches in the impeller, not painted-on marks. The marks in your pics were most likely done by a PO to make the job easier.
The best thing to do (in addition to using the Krusty method) is to verify TDC and make new marks for future adjustments. I think the Kap'n may go mover this in his article - it's been a while since I reas through it. |
jsf322 |
Mar 26 2006, 07:46 PM
thanks for the info. I believe this is actually the mark I should be looking at for cylinder 1 TDC. It is on the opposite side of the fan than the yellow marks. Thanks.
Triaddave |
Mar 26 2006, 09:14 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
there should be another mark close to where you are at. on one of ours, it a 0. on the other it is white. i think what you are showing is the 27 degree advance mark.
drewvw |
Mar 26 2006, 09:20 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
I agree. I did the valves this weekend for the first time as well and repainted the #1 TDC mark and the 27degree mark like that. There was no TDC mark on mine, but I did find a red dot for the timing mark and I painted the fan blade to make the mark bigger just like that..... find that little scribe mark on the distributor at 10 o'clock for #1 TDC and I bet that paint mark on the fan blade will be the 27 degree mark to the left of it (approx 2 inches). The pelican template printout helped me alot. http://www.pelicanparts.com/techarticles/9.../914_timing.pdf |
BMartin914 |
Mar 26 2006, 10:15 PM
That would be the mark, and yes, that is for 27' BTDC. The white notch is TDC.
jsf322 |
Mar 27 2006, 02:17 PM
amazingly I went completely around on the fan and there is no white mark. I did discover though that the yellow mark that a PO put on the opposite side of the fan does coordinate with the notch in the flywheel that you can feel on top of the transmission when you hit #1 or #3 TDC. I guess I have my marks. Thanks.
Lo-Fi Version | Time is now: 19th May 2024 - 07:57 PM |
