jsf322
Mar 26 2006, 04:14 PM
I was looking over my '76 2.0 getting ready to attempt my first valve adjustment and found marks different than what I had read. I found a yellow dot on the fan when the distributor rotor was pointing towards 7 o'clock and a notch in the flywheel through the opening on the bottom of the transmission. Is this cylinder #2 at TDC. I found another mark on one of the impeller blades when the distributor rotor was pointing towards the notch in the distributor housing. I assume this is the mark for cylinder #1 TDC but I am not sure. It did not look like what I expected. It was just a yellow line on the blade. I have attached some photos.
jsf322
Mar 26 2006, 04:16 PM
The picture above was with the distributor pointing towards the #2 wire tower. The picture below is the mark with the distributor pointing towards the notch in the housing which seems to go with the #1 wire tower.
echocanyons
Mar 26 2006, 06:52 PM
Use the Cap'n crusty method.
you can find it in the classic threads
The Cap'ns way
BMartin914
Mar 26 2006, 07:01 PM
The notches you need to look for are on the opposite side of the impeller than the painted marks in your pics - and they are actual notches in the impeller, not painted-on marks. The marks in your pics were most likely done by a PO to make the job easier.
The best thing to do (in addition to using the Krusty method) is to verify TDC and make new marks for future adjustments. I think the Kap'n may go mover this in his article - it's been a while since I reas through it.
jsf322
Mar 26 2006, 07:46 PM
thanks for the info. I believe this is actually the mark I should be looking at for cylinder 1 TDC. It is on the opposite side of the fan than the yellow marks. Thanks.
Triaddave
Mar 26 2006, 09:14 PM
there should be another mark close to where you are at. on one of ours, it a 0. on the other it is white. i think what you are showing is the 27 degree advance mark.
drewvw
Mar 26 2006, 09:20 PM
QUOTE (Triaddave @ Mar 26 2006, 07:14 PM) |
there should be another mark close to where you are at. on one of ours, it a 0. on the other it is white. i think what you are showing is the 27 degree advance mark. |
I agree. I did the valves this weekend for the first time as well and repainted the #1 TDC mark and the 27degree mark like that.
There was no TDC mark on mine, but I did find a red dot for the timing mark and I painted the fan blade to make the mark bigger just like that.....
find that little scribe mark on the distributor at 10 o'clock for #1 TDC and I bet that paint mark on the fan blade will be the 27 degree mark to the left of it (approx 2 inches).
The pelican template printout helped me alot.
http://www.pelicanparts.com/techarticles/9.../914_timing.pdf
BMartin914
Mar 26 2006, 10:15 PM
That would be the mark, and yes, that is for 27' BTDC. The white notch is TDC.
jsf322
Mar 27 2006, 02:17 PM
amazingly I went completely around on the fan and there is no white mark. I did discover though that the yellow mark that a PO put on the opposite side of the fan does coordinate with the notch in the flywheel that you can feel on top of the transmission when you hit #1 or #3 TDC. I guess I have my marks. Thanks.
