Finally had a day to myself, started on some long overdue projects |
brer |
Mar 26 2006, 08:57 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
Two weeks off from school, and so in between work and fixing the 300D I found some time for myself.
Took to the rear section and handled some long overdue corrosion. Then pulled the rear suspension to get powder coated. Next to get that old exhaust off in preparation for the new one that will go on before the rear end goes back in. Fix the shift bushing at the firewall and dick around with the rockers again while there's room. change oil, install new temp sender to match combi guage. scrub scrub scrub and then wait to do the front end. got alot done, but i had help this time. check it out. Attached image(s) |
Lo-Fi Version | Time is now: 28th May 2024 - 10:52 AM |
