> Wheel bearings this weekend ?!, What is it gonna take...
RangerRhett
post Mar 27 2006, 07:27 PM
Hey all...
I was going to tackle my front wheel bearings this weekend (or next). What am I going to need...?
I assume the Front Inner and Outer Bearings...but a wheel seal?
Front Inner
http://www.pelicanparts.com/cgi-bin/smart/...=311405625D-M92
Front Outer
http://www.pelicanparts.com/cgi-bin/smart/...n=311405645-M92
Wheel Seals?
http://www.pelicanparts.com/cgi-bin/smart/...311405641B-M213
Are any special tools going to be required?
thanx
Rhett...
Replies(1 - 6)
solex
post Mar 27 2006, 07:48 PM
Flat head drift to remove the old races, and a large socket to go over the new races when you pound them in.
If your seals are in good shape then you do not have to replace them but if you do not know then get new ones.
Dan
RangerRhett
post Apr 8 2006, 06:46 PM
QUOTE (solex @ Mar 27 2006, 05:48 PM)
Dan
Can anyone help me...
What is a Flat Head Drift???
Joe Bob
post Apr 8 2006, 06:50 PM
BF Screwdriver....
RangerRhett
post Apr 8 2006, 06:51 PM
QUOTE (! @ Apr 8 2006, 04:50 PM)
BF Screwdriver....
Big-F@&king Screwdriver?
Spoke
post Apr 8 2006, 09:04 PM
Jerry
To pound out and pound in the bearing races, I use a brass drift. It's basically a brass punch which will deform upon impact instead of damaging the race.
Brass Drift Set
Tap-tap on one side, tap-tap on the other side. Do this continuously until the old race falls out. Do the same thing to install the new race. The drift will show signs of deformity but the races will be spared any harm.
Not a hard job. Just takes some patience. Some people cool the new race so it shrinks a bit and fits in better. I did this on the first bearing race, then came to the conclusion that by the time the race was half way in, it had returned to room temp and lost its "shrinkage".
I changed the seal since it was only a couple of bucks at my FLAPS.
Spoke
watsonrx13
post Apr 9 2006, 07:02 AM
Here's a link to my website that shows the procedure I used to replace the front wheel bearings....
BTW, if someone has the www button at the bottom of their posts, it means they have a link to their website. You might try the links sometime....
-- Rob
- Lo-Fi Version Time is now: 1st May 2026 - 09:29 AM
