Flasher relay |
Flasher relay |
Ctrout |
Mar 27 2006, 10:52 PM
Member Group: Members Posts: 377 Joined: 20-May 04 From: Mountain Home, ID. Member No.: 2,091 |
My turn signal relay started clicking continuously recently. Only the relay clicks, the turn signals still function normally. Has this ever happened to anyone here?
JJ914 |
Mar 27 2006, 11:02 PM
Big JJ Group: Members Posts: 90 Joined: 30-December 04 From: Augusta GA Member No.: 3,374 Region Association: None |
You got mail
fiid |
Mar 28 2006, 09:48 AM
I have similar problems - let us know what you find....
Ctrout |
Apr 13 2006, 05:51 PM
Got a new relay from Pelican today. Problem solved.
Mueller |
Apr 13 2006, 05:56 PM
yep, I had to do the same thing....I tried a generic relay from NAPA, didn't work too well....paid for a correct relay and they work perfect...
Tobra |
Apr 13 2006, 07:22 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Ctrout |
Apr 13 2006, 11:34 PM
I wish you had replied to this thread sometime like oh, two weeks ago when I posted it!
Tobra |
Apr 14 2006, 11:13 AM
I wish you had replied to this thread sometime like oh, two weeks ago when I posted it! Sorry brother, I help out when I see something I struggled with...there are a number of VW parts that are perfect fits, and waay cheaper. IE, said relay, the cover to the fuse box is a match for one out of a 75-79 bug, with numbers 1-12 instead of little pictures, for about 75% less. The interior light is also really similar to a VW ( beetle sedan I think). There is a lot of stuff, we should make a list. I would also encourage you to pull the ground, and clean all the contacts in the fuse block, that helped make my headlights brighter, go figure |
Ctrout |
Apr 15 2006, 01:02 AM
Thanks for the info. I happen to be in the market for a fuse cover. Keep kicking out the one for the running lights. Great idea, building a list. I don't have any idea what parts are compatible. Anybody want to take a crack at this?
Lo-Fi Version | Time is now: 15th May 2024 - 01:56 PM |
