got a vac. leak, could it be.. |
toon1 |
Mar 28 2006, 11:08 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I have a vac leak at the runner/ head union. I have replaced the gasket with a new, thick paper gasket. I surfaced the face of the runner where it mates with the gasket with some wet sand paper and a peice of granite tile.
Put it all back together very clean and with a little gasketsinch. When I fired the motor up it was fine. But yesterday after my drive home from work I noticed a fluctuating idle, sprayed some carb cleaner in that area on the rpm went up. Is it possible the runner has a crack?? |
Bleyseng |
Mar 28 2006, 11:35 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
No, but I bet your fuel injector inner seals are shot.... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
toon1 |
Mar 28 2006, 11:53 AM
is it the seal that is on the end of the injejtor that makes the seal agains the runner? that is new. Is there an injector seal internally? |
Rand |
Mar 28 2006, 12:04 PM
If I understand which one you're talking about, the correct gasket is a lot thicker than paper... (IMG:http://www.pelicanparts.com/catalog/images/fuel_injection/914_intake_manifold_gaskets.JPG) The injectors seals are like little rubber donuts that fit around the injector... (IMG:http://www.pelicanparts.com/catalog/images/fuel_injection/914_injector_seals.JPG) |
toon1 |
Mar 28 2006, 12:53 PM
Yep, both are new, the manifold gasket is new with the thicker paper, the injetor seals are new on the all 4 injectors, big and small seals are new. This is the second new man. gasket on this side that is why I am suspect of something else. The manifold gasket on the drivers side of the motor is the thin paper type gasket and it is sealing fine. |
ClayPerrine |
Mar 28 2006, 12:58 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The manifold gaskets are not just paper. They are a plastic insulator between 2 paper gaskets.
You need the proper spacer with the gaskets. It won't run right with just a paper gasket. |
toon1 |
Mar 28 2006, 01:09 PM
I have the bakelite piece in. It is brand new, never used, paper is bonded to the bakelite, it's all good. after two new gaskets, I think it is some thing that I am putting back on or the head is warped??? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
Bleyseng |
Mar 28 2006, 01:15 PM
Well, I have seen the engine tin stick out into where the Phenolic block mounts to the head preventing a solid seal. Check for that.... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/jsharp.gif) |
toon1 |
Mar 28 2006, 01:34 PM
good point, I had that problem on the other side and corrected it before installing the gasket. This side is clear of the tin. |
Bleyseng |
Mar 28 2006, 01:58 PM
try a different gasket compound like Copper or Curel to seal it.
toon1 |
Mar 28 2006, 02:03 PM
ok! what is copper and curel?? sealants? NAPA auto?? |
Bleyseng |
Mar 28 2006, 02:26 PM
sealants...
toon1 |
Mar 28 2006, 02:30 PM
how do they differ from gasketsinch?? |
Lo-Fi Version | Time is now: 17th May 2024 - 03:31 PM |
