GRRRRR |
GRRRRR |
-P- |
Sep 13 2003, 05:40 PM
P-Factor Group: Members Posts: 207 Joined: 1-July 03 From: Dallas, TX Member No.: 873 |
Well it started out as a nice day replacing the strut inserts on my car. Did the 1st side, and after realizing how it all worked realized you didnt need need to pull the strut off to replace the insert moved on to the second. 30 minutes later while giving everything a once over on the second side I noticed a bit of play in the strut when shaking it making sure everything was secure.. I though for a moment and didnt remember putting the collar on the strut insert. So I check the box and there is none to be found. I read the box (which was obviously opened before) and saw "Def" written on it. The strut had never been installed but the collar was missing.... So no driving this weekend and early this week until I contact Pelican. Needless to say I am a bit pissed as I already had to settle for the Bilsteins after they called a couple days past when the order was placed and asked what else I would settle for because they were out of Konis sports....
I will call them 1st thing Monday and I am sure they will make it right. On a side note, every single Koni that I took off, both front and back, was leaking, and leaking bad. Lessons learned: Pipe wrenches kick ass Check the boxes for all the pieces before you start. The second side on a project always goes 100% quicker. |
mharrison |
Sep 13 2003, 05:47 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
Gee this sounds like my life!!! It'll be worth the wait when it's all done though....(that's what I always tell myself!)
-P- |
Sep 13 2003, 05:48 PM
QUOTE(mharrison @ Sep 13 2003, 05:47 PM) Gee this sounds like my life!!! It'll be worth the wait when it's all done though....(that's what I always tell myself!) That is what kept me from throwing things at people near by (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/beerchug.gif) |
TimT |
Sep 13 2003, 07:13 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
interesting... there are a couple of negative threads about pelican on pelican today.... interesting
Aaron Cox |
Sep 13 2003, 09:53 PM
i almost did the same thing. paragon had koni's- and they were a little cheaper. (IMG:style_emoticons/default/boldblue.gif)
seanery |
Sep 13 2003, 10:22 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,852 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
DUDE, you're in Texas! Buy from Jason at Paragon!
They had the best prices on yellows, too! Paragon Web |
-P- |
Sep 16 2003, 09:37 PM
Pelican made good on their blunder as expected and I installed the struts tonight after they next day aired me a new one. It almost feels like a new car (IMG:style_emoticons/default/smile.gif).
Now to tighten up the steering, then shifter, then brakes. |
Brad Roberts |
Sep 16 2003, 11:36 PM
You should have never accepted the Bilsteins... they work great (and I use them.. but only when the customer wont pop for adj. Koni's)
Not sure if you asked the BBS or not.. but I would have told you that you didnt need to remove the strut. B |
-P- |
Sep 17 2003, 03:00 PM
QUOTE(Brad Roberts @ Sep 16 2003, 11:36 PM) You should have never accepted the Bilsteins... they work great (and I use them.. but only when the customer wont pop for adj. Koni's) Not sure if you asked the BBS or not.. but I would have told you that you didnt need to remove the strut. B Yeah I know, but whats done is done. The Bilsteins seem fine for my use. The brake system got a good flushing though (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:23 AM |
