Has anyone used a 911SC rear bar on a 914?, sway, that is. |
Dr. Roger |
Mar 28 2006, 03:09 PM
Seems like it should be an easy fab of the body mounts.....
thanks... Roger |
Mueller |
Mar 28 2006, 03:28 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif) |
Dr. Roger |
Mar 28 2006, 03:32 PM
Mueller |
Mar 28 2006, 03:41 PM
1st off, why not use a 914 designed bar that you know for sure fits??
what size are the 911SC rear bars? You do not want a bigger rear bar on the front than the rear on a 914. |
Aaron Cox |
Mar 28 2006, 03:42 PM
unless it has MONGO rear tires and doesnt rotate easily (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif) |
Dr. Roger |
Mar 28 2006, 03:52 PM
the rear 911 bar is an 18mm..
my stock 914 front bar is 14mm i think. mike, it's all about the price.... CSOB that i am. =-) |
SLITS |
Mar 28 2006, 03:55 PM
Mount it in the rear trunk like the GT? cars and then blow your supposed savings on fabricating the drop links and mounts.
Then go buy a 22 mm front bar to offset the 18 mm back bar and................... |
Aaron Cox |
Mar 28 2006, 03:56 PM
stock 914 rear bar = 16mm (but look at the arm lenght) stock 914 front bar = 15mm |
Aaron Cox |
Mar 28 2006, 03:57 PM
he has 295's in rear.... and 225? up front.... its going to plow like a mother |
SLITS |
Mar 28 2006, 04:00 PM
Not with the V8 in it....it'll rotate like a top................. (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif)
Aaron Cox |
Mar 28 2006, 04:06 PM
I doubt it.... |
Dr. Roger |
Mar 28 2006, 04:14 PM
the car is setup right now with no bars. 911 front suspension and 140# rear springs.
i have the stock front sway bar sitting on the fur covered burning man surf board mobile. =-) my thoughts are to drive it a bit with nothing. then install the front bar. then drive it a bit. then install something on the rear. then drive it a bit. then make final decisions on "adjustment" on either the front or rear to get her balanced. |
Mueller |
Mar 28 2006, 04:17 PM
install the front bar for sure.........
Twystd1 |
Mar 28 2006, 04:21 PM
140 Lb rears..
I don't know shit... Cept that seems way to light to me... Me thinks some of us have a set of 180s or 200s that you could have for very cheap.. It's worth looking into in MHO... Then again...run what ya got. Thats a place to start.... Clayton |
Aaron Cox |
Mar 28 2006, 04:26 PM
werd.... im running 225's on a 4 banger.... on full throttle, your v8 will drag the rear...... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Mueller |
Mar 28 2006, 04:29 PM
he is going for that "floating" '70's Caddy feel (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
Dr. Roger |
Mar 28 2006, 04:51 PM
truth be told the most sporty/handling car i've ever owned was a '63 karma ghia convertible w/a 1600cc single carb into a 4-1 stinger exhaust. LOL
this 914 already walks around everything i've ever owned in the handling department. |
Eric_Shea |
Mar 28 2006, 06:12 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
If it's all about price then I don't understand the logic of actually buying something that will ruin your handling... no matter what the price. Hell... even if it's $5.00, that would buy another roll of duct tape and some plastic ties to hold the radiator in (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (just tease'n ya pookie) |
Dr. Roger |
Mar 28 2006, 06:29 PM
sorry eric,
=-) just trying to be one of those "out of the box" thinkers. these 911 rear sway bars are pretty hefty for a 914 i think. probably too much for my car but i think i'm going to get the front/rear set anyways as they are local and only $50. after researching online, one 911 rear bar alone, new, is over $300. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) anyone wanna set of 911 bars???? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Twystd1 |
Mar 28 2006, 06:37 PM
I'll give ya 50.00 bucks for the bars + shipping.. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Clayton |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:26 PM |
