sway bar swap |
sway bar swap |
sk8kat1 |
Mar 29 2006, 11:21 AM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
so if I already have stock sway bars -- do you really and truely have to remove the gas tank to swap them out?
Aaron Cox |
Mar 29 2006, 11:25 AM
you have front and rear sway bars??
you are goingto a BIGGER front bar i assume? if the brackets are already in, then i see no reason to pull the tank to swap the front bar. just pull it out from one side and put the new one in.... but it aint rocket science to pull your tank (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) and NO, you dont need to pull the gas tank to swap your rear swaybar (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
sk8kat1 |
Mar 29 2006, 12:40 PM
I do have rears already .. and yes going to a 19mm front ..
and I do already have the triangle lookin things and the u tabs on the a arms... sounds easy! oo and it didn't look like rocket science to pull the tank just I have the front and rear of the car torn apart and on jackstands.. of course (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) and really didn't want to deal with the possibility of tring to drain a full tank of gas or even try and figure out what to do with it ... thanks !! |
Joe Ricard |
Mar 29 2006, 01:55 PM
The only tough part is getting it through the hole at the far end.
rhodyguy |
Mar 29 2006, 02:13 PM
it seems like i always add to your "do list". if you have never taken your tank out or changed the fuel lines to the tank now would be the time to do it. there's prob going to be a bit of rust under it too. sorry.
k |
jd74914 |
Mar 29 2006, 02:42 PM
So . . . I call dibs on the stock from when it comes out (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
sk8kat1 |
Mar 29 2006, 02:47 PM
I thought that too... I think I might do the whole attach a string the end of teh old one so that when the old one is pulled out the string is left behind to attach to the new and hel pguide it to the other side ...
that thar is texan tech (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ----string and duct tape |
sk8kat1 |
Mar 29 2006, 02:48 PM
dibs noted (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
sk8kat1 |
Mar 29 2006, 02:52 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) but if I have a ful tank of gas what should I do considering my car is dry docked
rhodyguy |
Mar 29 2006, 03:06 PM
leave the tank in and try to do the bar swap? worst case... you won't be able to fish the bar in and will have to drain the tank.
k |
maf914 |
Mar 29 2006, 03:13 PM
When I drained my tank I simply transferred the gas to my old pick-up truck, about 8 gallons. No problem. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Do it in a well ventilated space and keep a fire extinguisher handy. Have some shop cloths to clean up spills. And a helper on standby doesn't hurt either. |
sk8kat1 |
Mar 29 2006, 03:42 PM
so what is the best place to pull a hose to drain the tank? .. m
man K you do keep adding to my todo list every time you post!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
jd74914 |
Mar 29 2006, 04:00 PM
I'd siphon it out. and into a bucket or directly into another car
Lo-Fi Version | Time is now: 19th May 2024 - 05:54 PM |
