oil, In the plenum |
toon1 |
Mar 30 2006, 02:49 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I removed the throttle body and found oil in the plenum, I know this shouldn't be.
I have the hose for the PCV plugged in to the plenum, is that correct? Other possibilities?? |
Dave Bell |
Mar 30 2006, 02:58 PM
Member Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None |
Oil vapor gets sucked up the breather, through the hose connection to your air intake and all down into all intake system.
- Dave |
sjhowitson |
Mar 30 2006, 02:59 PM
Member Group: Members Posts: 478 Joined: 4-August 04 From: Moraga, CA Member No.: 2,449 |
Do you have an oil bath air cleaner?
lapuwali |
Mar 30 2006, 03:04 PM
Do you mean a substantial puddle of oil in the plenum, or just a misty coating? I doubt there are many 914s out there that DON'T have a coating of oil mist in the plenum, primarily from the breather.
toon1 |
Mar 30 2006, 03:20 PM
It was more like heavy film. It seems like more than it should be.
I removed the PCV valve and it looked clean. It is not the oil bath type air cleaner. |
Mar 30 2006, 05:29 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
unless you've got 1/4" of standing oil in there, it's perfcetly fine. the oil comes from the PCV valve on the filler and from the head vents. it's supposed to be sucked through there and burnt ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
toon1 |
Mar 30 2006, 05:34 PM
OK that makes me feel better. Now, a new problem. I took off the TB to set the TPS reinstalled everything fired the car up and it was sitting at 3k and would nor come down. BAck under the engine grill I go...... |
lapuwali |
Mar 30 2006, 06:21 PM
Air leak. Either you forgot a hose, or the TB gasket needs to be replaced.
toon1 |
Mar 30 2006, 06:48 PM
can it be tuned inside out and reused? what else can be done?? |
lapuwali |
Mar 30 2006, 06:55 PM
You could scrape all the old gasket off the TB and the plenum and use goop. More likely you forgot a hose. Does the throttle close all the way?
toon1 |
Mar 30 2006, 07:09 PM
that was the first thing I checked it was closed. all the vac lines are good and connected. I will try again. (IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) my own thread what is a good torque on the intake bolts? |
Lo-Fi Version | Time is now: 9th May 2024 - 11:59 PM |
