| TomL |
Mar 30 2006, 05:15 PM
Newbie ![]() Group: Members Posts: 13 Joined: 10-October 04 From: Lubbock, TX Member No.: 2,916 |
I am hoping to build a good, solid, higher performance Type 4 which will be used as a daily driver, touring car and perhaps an occasional AX. I have some questions.
1. Are all type 4 engine cases identical? If so, why are "GA" cases preferable? 2. What practical difference is there between a 78.4 stroke crank and an 80mm crank--since the 80mm seems to be more prevalent and a little less expensive? 3. Which is the most preferable bore--94mm, 96mm or 103/4mm? 4. Is there any practical difference between standard 2.0 sized crank journals and chevy sized? 5. Can 1.8 heads be "massaged" enough for decent performance? 6. Pure speculation--What kind of HP might I expect out of an engine with: 80mm stroke, 96mm bore, a moderate cam, re-worked 1.8 heads (8.5 or 9:1CR) and carbs? Thanks for any answers you can give TomL |
TomL Type 4 Engine build basics Mar 30 2006, 05:15 PM
cnavarro What kind of budget do you have set aside? That wi... Mar 30 2006, 05:59 PM
Jake Raby Someone needs a RAT engine kit.
Guess work= Non e... Mar 30 2006, 06:02 PM
Bleyseng All type 4 cases are basically the same:
Early cas... Mar 30 2006, 06:07 PM
azbill Save yourself a lot brain damage. Get a 2056 kit f... Mar 30 2006, 06:20 PM
Jake Raby Bill speaks from experience...
... Mar 31 2006, 05:15 PM
Dave_Darling Mar 31 2006, 07:37 PM
TomL Thanks to everybody who has taken your time to res... Apr 1 2006, 07:42 AM
DNHunt Dave
My 78.4mm DPR crank with type 1 journals nee... Apr 1 2006, 08:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 04:28 AM |
