My Subaru 914 EJ20T |
EJ20Tim |
Mar 30 2006, 09:07 PM
Newbie Group: Members Posts: 6 Joined: 24-August 05 From: Florida Member No.: 4,656 |
Hey fellas, just got my page up. Thought you guys might be interested in some good pictures of an EJ20T swap into a 73 914. I will try to keep it updated every week or 2 till I'm done. Enjoy.
http://914turbo.airflowlogistics.com/ |
firstknight13 |
Mar 30 2006, 09:23 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) very kool!!! i am doing the SAME conversion (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) what are you doing for the wiring harness and heat??? thanks, ray
grasshopper |
Mar 30 2006, 09:26 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
EJ20Tim |
Mar 30 2006, 09:50 PM
FirstKnight, I am going to use the factory harness and solder up an adapter harness to fit the megasquirt. I'm not sure which heat you're referring to. If its the engine cooling I plan on running a radiator up front and a SHO fan (fiy you can buy these at the junkyard on the dirt cheap from a SHO Taurus and they flow 5500cfm). If you're referring to heat as in climate control, this car will prob not have any since I live in Florida. I would love to see some pictures of your project if you've got them.
-Tim |
brokenmoped |
Mar 30 2006, 09:52 PM
Member Group: Members Posts: 143 Joined: 27-May 05 From: Mission Viejo, CA Member No.: 4,152 |
May I ask where you picked up the engine and for how much?
firstknight13 |
Mar 30 2006, 09:57 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) i got my engine from ebay from enginesrus 1100 with shipping i think........ (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
EJ20Tim |
Mar 30 2006, 10:40 PM
I got it from http://www.nippon-motors.com/subaru.htm. It was $960 by the time it was shipped to a local freight terminal.
TonyAKAVW |
Mar 31 2006, 12:50 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I actually went to the Nippon Motors warehouse to look at motors a while back. Its essentially this giant warehouse full of engines.
They didn't have ECUs or much in the way of harnesses. Apparently its really tough to get "front clips" but they were trying to get them. They know that everyone wants the ECUs and harnesses, btu the impression I got was that they don't often get them. Good work on the conversion! Can't wait to see the results. -Tony |
URY914 |
Mar 31 2006, 07:30 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,510 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Tim,
Where in Florida are you? Paul |
d914 |
Mar 31 2006, 07:49 AM
I'm looking at wo options for the turbo:
- custom up pipe that would move the turbo forward and to the right - or the "outback" header that puts the turbo in front of engine. turn the intake and move the alternator to the a/c spot and away you go..no cut Attached image(s) |
d914 |
Mar 31 2006, 07:52 AM
header
EJ20Tim |
Mar 31 2006, 01:40 PM
URY914, right down the road. I'm in Tampa. I wouldn't mind checkin out that lightweight 914. WHat kind of engine u runnin?
D914, I have considered almost every possibilty to not cut this car. Unfortunatley, I have to cut the front anyways to put the radiator in. I had considered a rear mount radiator but I did not have enough room after moving the trans and engine forward. But I will say, I haven't cut a thing yet. I'm waiting to get everything mounted so I can cut as little off as possible. |
Lo-Fi Version | Time is now: 11th May 2024 - 05:05 AM |
