Crank end play, i ain't got no... |
swood |
Sep 14 2003, 08:32 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Put in the rear seal, 3 shims and all to check the end play, and the flywheel does not seem to budge. It's real tight. If .003-.005" is the tolerance, does it stand to reason that a shim should be removed to get that tolerance? Seems strange that it's that tight. I'll double check it again anyways.
What is the purpose of the felt anyways? |
cgnj |
Sep 15 2003, 09:29 AM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
This is measured without the rear seal in. The only felt piece I can think of is the felt ring that goes between the pilot bearing and large flywheel washer. Carlos |
ejm |
Sep 15 2003, 09:53 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The felt piece keeps dirt out of the needle bearing and the grease in. You can measure the end play with it and the crank seal removed. Depending on how assembled your engine is it might be easier to mount a dial indicator and measure the end play at the fan end of the crankshaft.
KenH |
Sep 15 2003, 05:20 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
The dimensions of the case, bearings & crank are slightly different from part to part.
If the crank has too much end play it will beat the case and bearings. If it has too little it will wear the main bearing or the case. You have to check it with a dial gauge. There is no way you can "feel" 3-4ths. First verifiy the crank turns freely WITHOUT the shims. Then install the crank and shims and TORQUE to spec. If tight - you will need to use larger shims - if it turns OK then you need to measure the end play. If to much, or too little, record the measurment. Remove the flywheel and measure the shim pack. Calculate the new shims need to give the correct end play. Bolt it up and remeasure. You must use 3 or more shims. Various size Shims are avilable from the dealers. Ken |
JeffBowlsby |
Sep 15 2003, 05:36 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
QUOTE You must use 3 or more shims. I recall that it is 3 and only three shims. |
Rouser |
Sep 15 2003, 06:23 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
If you have the fan pulley attached on the other end and you omitted the required spacer (so you can turn the crank), make absolutely sure none of the three fan bolts are protruding from the back of the crank mount.
These WILL jam up against the front oil seal, tearing it up and frustrating the measurement you're trying to achieve. Um ... it's not like this ... um ... happened to me or anything ... |
swood |
Sep 15 2003, 07:07 PM
Thanks for the replys guys. This motor is being assembled from a complete tear down. The same crank is being used after being polished and balanced, same for the flywheel. Same case as well. I guess I'm trying to figure out why the end play would change from what it was pre-teardown. Same fly shims too. I'll go back and check the play from both ends.
With the new bearings, all rotates as smooth as silk. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:00 PM |
