tranny drain plug stripped, what to do |
drewvw |
Apr 3 2006, 04:52 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
I went to change my tranny fluid today and found that my drain plug is rounded out pretty good. Fill plug is fine, and I was happy to find she was at least filled with oil. Questions: 1) Whats the best way to get this thing out of there? I don't have a welder. Can I JB Weld a hex bolt in there and break it free? Looks like it hasn't moved in decades. 2) I took out that plug on the bottom (the one with the spring and ball bearing) in an attempt to get it to drain. Went back in fine...did I screw anything up by taking it out?? Thanks in advance... drew |
Danny_Ocean |
Jan 7 2008, 08:50 PM
Member Group: Members Posts: 170 Joined: 27-June 07 From: Fort Lauderdale, FL Member No.: 7,846 Region Association: South East States |
Can you drill out the plug with a slightly smaller drill-bit (17mm), then (carefully) chisel away the remaining threads? How about hitting it with a reverse drill-bit?
racunniff |
Jan 7 2008, 08:52 PM
volt914 Group: Members Posts: 172 Joined: 21-August 06 From: Fort Collins, CO Member No.: 6,705 Region Association: Rocky Mountains |
Can you drill out the plug with a slightly smaller drill-bit (17mm), then (carefully) chisel away the remaining threads? How about hitting it with a reverse drill-bit? I think drilling the whole thing out is asking for metal flakes in your tranny. A reverse drill-bit is a good idea - I bought a large screw extractor as my backup plan - but I did not have to go there. The bolt trick worked just fine. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:55 PM |
