tranny drain plug stripped, what to do |
drewvw |
Apr 3 2006, 04:52 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
I went to change my tranny fluid today and found that my drain plug is rounded out pretty good. Fill plug is fine, and I was happy to find she was at least filled with oil. Questions: 1) Whats the best way to get this thing out of there? I don't have a welder. Can I JB Weld a hex bolt in there and break it free? Looks like it hasn't moved in decades. 2) I took out that plug on the bottom (the one with the spring and ball bearing) in an attempt to get it to drain. Went back in fine...did I screw anything up by taking it out?? Thanks in advance... drew |
Porcharu |
Jan 8 2008, 01:51 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
Did you ever get the plug out?
racunniff |
Jan 8 2008, 09:04 PM
volt914 Group: Members Posts: 172 Joined: 21-August 06 From: Fort Collins, CO Member No.: 6,705 Region Association: Rocky Mountains |
Did you ever get the plug out? Yep. That last pic is the fill plug out. I welded the bolt to it after it was out. My new ones just showed up from The Bird, and, thanks to the tips to check out Auto Zone, I have a 17mm Allen socket to put them in with (no more round corners!) I need to pull the tranny here before too long - the mainseal is leaking - so I'll replace the drain plug at that time. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:07 PM |
