tranny drain plug stripped, what to do |
drewvw |
Apr 3 2006, 04:52 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
I went to change my tranny fluid today and found that my drain plug is rounded out pretty good. Fill plug is fine, and I was happy to find she was at least filled with oil. Questions: 1) Whats the best way to get this thing out of there? I don't have a welder. Can I JB Weld a hex bolt in there and break it free? Looks like it hasn't moved in decades. 2) I took out that plug on the bottom (the one with the spring and ball bearing) in an attempt to get it to drain. Went back in fine...did I screw anything up by taking it out?? Thanks in advance... drew |
Tobra |
Apr 3 2006, 11:06 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Why change the oil at all? Come now Cap'n, you disappoint me. The oil degrades with time and heat cycles also. My tranny leaks, but not enough that just topping it up is adequate to my mind, regardless of any factory recommendations. Why not cut a piece of allen wrench, J-B weld it to make your male drain plug. No heat, and that J-B epoxy is pretty tough. If you screw that up, you could still cut it off flush and drill it out, though a piece of allen wrench might be pretty hard to drill... |
Lo-Fi Version | Time is now: 5th May 2024 - 06:50 PM |
