tranny drain plug stripped, what to do |
drewvw |
Apr 3 2006, 04:52 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
I went to change my tranny fluid today and found that my drain plug is rounded out pretty good. Fill plug is fine, and I was happy to find she was at least filled with oil. Questions: 1) Whats the best way to get this thing out of there? I don't have a welder. Can I JB Weld a hex bolt in there and break it free? Looks like it hasn't moved in decades. 2) I took out that plug on the bottom (the one with the spring and ball bearing) in an attempt to get it to drain. Went back in fine...did I screw anything up by taking it out?? Thanks in advance... drew |
bondo |
Apr 4 2006, 05:39 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
It also fills with brass and molybdenum bits which won't stick to the magnet. And being vented, it certainly has the possibility of picking up dirt and moisture. I certainly don't think it needs to be changed often..
I'm sure most of the time you can get by without ever changing it... But I don't see there being no reason to change it for fresh occasionally. It's worth it to me, for the purposes of ensuring maximum performance and lifespan, to change it every few years. Ya gotta get under there to check the level anyways, might as well get the shimmery glitter bits out, clean off the magnet, and make sure your drain plug doesn't fuse in place. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Lets start a synthetic vs. non vs leaks vs syncro effectiveness vs wear argument now.. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 11:11 PM |
