bwilless |
Member ![]() ![]() Group: Members Posts: 156 Joined: 24-January 03 From: Tempe, AZ Member No.: 192 ![]() |
I've tried contacting Brad about this car, but he must be out of town or just busy. So I thought I'd ask the population. I'm interested in buying Toby's 914-6. I searched the board and Brad made a comment . . .
"It needs about 10k worth of work to make it cherry (paint+body work/wiring/cooling)" Does anyone know the basis for this statement? Are there wiring issues, or could it be done better/nicer. What about the cooling issue? Does it run hot, or could the cooling system be done better? What about the body work/paint. Is it chipped up, or is there damage that needs to be fixed? Any information would be appreciated. I'm not necessarily looking for a cherry car, but I don't want to have to put allot of money into it to start enjoying it right away. Thanks, Brian Tempe, AZ |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
AFAIK, the cooling system is in good shape. It was crap for a while, but Tobias had the cooler replaced and some real ducting and such made. I forget if it has a fan on the cooler--if not, it will need one for traffic situations most likely.
Body: Again, AFAIK, it's solid. But it's UGLY! Nasty 70's paint scheme--white with the black/grey/silver stripes. I don't think the paint is in very good shape, but what I remember is just that it's older paint that needs some care. (Or a total repaint if you don't want that nasty paint scheme!) The front deck lid may still have the louvers cut into it, which aren't needed. I don't remember the 916 bumpers being fitted all that well. It only had a roll bar last I saw; a cage would probably be more appropriate. Does it all add up to $10K? Not sure... But it's a heck of a deal either way!! --DD |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Has fiberglass flares, and the paint is cracking in a number of places where the flares are joined to the body. If I remember correctly, one of the fiberglass flares has some damage as well.
It really depends on what you want out of the car. If you want a cherry looking car, then it needs some $$ and work. If you are looking for a brutally fast autocross and track weapon (always a top time of day contender in autox, not sure about track), then you've found your car. Demick |
bwilless |
Good input so far, thanks. How about the wiring issues Brad mentioned. Know anything about that?
Lo-Fi Version | Time is now: 13th July 2025 - 10:29 AM |
