Weekend recap, get any work done? |
drewvw |
Apr 9 2006, 07:02 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
Sunday recap time. I replaced most of my vacuum lines and ripped out the plastic fuel lines in the engine compartment. To be continued tomorrow... oh yeah, I did some stuff around the house too (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Lou W |
Apr 9 2006, 07:19 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Today I drained the old gas out of the gas tank, I'm sending out to a local radiator shop and have it boiled out tomorrow, then it's off to the powder coater. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Trekkor |
Apr 9 2006, 07:25 PM
VaccaRabite |
Apr 9 2006, 07:27 PM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Well, I just replaced the filters and wipers on my Subaru. I looked really hard at the 914, though. Really hard.
Zach |
drew365 |
Apr 9 2006, 07:28 PM
Sat. I pulled off the front calipers and rotors. Time for new brakes.
Sun. Started to refinish my fireplace with limestone. Got to balance house and car. |
Tobra |
Apr 9 2006, 07:30 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
It is raining out there again man, get a tarp on it, or not... Went to do my undertank fuel lines, and discovered my hose clamps are too big, and that the fuel pump and filter are in the front, took off cover for MC and et voila! Sort of a funky looking pump, I told that dude I bought it from the pump was in front and he said, "No, I don't like that" Decent looking install though. will try a pic in the dark. Had a second set of hands, so I put the second horn on, have to get different clamps, DOH. Did the petronix last week, finally got my firewall bushing so that is next weekend. |
URY914 |
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,725 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I changed the size of my carb jets to 140 mains and 55 idles and worked on the f-glass targa bar.
Changed the oil and filters in the tow rig. Reinstalled the winch on the trailer and begin to mount the tool box. Does that count? |
drewvw |
Apr 9 2006, 07:32 PM
Oh that counts I think... |
bernbomb914 |
Apr 9 2006, 07:35 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I worked on the motor home. I replaced the flooring and all the furniture, had a new dinette built and my wife is making new curtians. its been a long choir but it is almost done. Leaving for Sedona on the 15th for a week and the wife wanted the motorhome cleaned up. Its a 89 and has had some hard use but it looks like new now.
Bernie |
jasons |
Apr 9 2006, 08:23 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I took my inaugural drive in my $1300 craigslist car. When I got the car, the PO told me it didn't start he didn't know why. I don't know either, I just shot some starting fluid in it and it fired right up. Then it proceeded to try and destroy itself by leaking fuel like crazy. So... I procured some new FI line and fixed the leaks. Actually there is a loose wire on the cold start valve, so maybe thats why he had trouble. I adjusted the valves pulled up some carpet, new plugs, new throttle cable. Now, I have a better of assessment of the good and bad in this car.
GOOD (IMG:http://www.914world.com/bbs2/html/emoticons/clap56.gif) New Bilsteins in the back w/ some kind of performance springs. Front and Rear factory Sway bars. Good 2.0 SS heat exchangers. rebuilt? 2.0 motor (appears rebuilt and I was told as much) Weltmeister shift kit 911 SC front struts SC (I think) Fuchs Hella H4 conversion on the headlights Good condition painted early bumper (no holes) Console(needs recovered) BAD (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Some kind of rigged up clutch tube fix with bailing wire Been hit in the front where the passenger door meets the front fender. This has induced some long rust. Has a broken exhaust stud, and another one has been drilled out and never replaced. No exhaust hanger. Missing some FI stuff. Has hell hole rust, jack post rust, some firewall rust. So, I'm a littled bummed about the body issues. But, the good stuff far outweighs the bad. Also, I have a pretty clean roller that has never been hit, but still needs paint and body and some rustoration. I can't bitch, I did pretty good for $1300 plus a tow truck. (IMG:http://members.cox.net/jasons7/914redsmall.JPG) |
DanT |
Apr 9 2006, 08:28 PM
This week,
front sway bar went in, oil cooler was finalized and lines run, fan wiring completed to foglight circuit, Fuchs installed with Kumhos, ride height was finalized and we are ready for the first track event. CDS at BW 4/15-16 front trunk Attached image(s) |
DanT |
Apr 9 2006, 08:29 PM
ride height and Fuchs, ready to go to the track now.
Flat VW |
Illegal Soapbox Derby Racecar Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
it is pink! John (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
degreeoff |
Apr 9 2006, 08:32 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
welded in my new rear pans, fixed (with author-it-tye) the clutch tube, turned my 72 tail shifter firewall rubber boooooty thing into the sideshift rubber booooty thing (AKA small boot fits now)
and the engine compartment is almost paint rust grease free next week is the cage fitting and suspension tie in (to the cage) |
ClayPerrine |
Apr 9 2006, 08:35 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I tuned the six up and put in hotter plugs to cure the plug fouling I have been experiencing. I also replaced one bad plug wire end.
I need to finish up tomorrow by resyncing the MFI stacks and resetting the idle speed. Friday I am off work, so I am going to do oil changes on both 914s and adjust the park brake shoes on mine. |
blitZ |
Apr 9 2006, 08:37 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Installed David Lee's towbar, thanks Dave. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Removed and packed injectors to send to CruzinPerformance for refurbishing. Ripped out the remaining air injection plumbing, compartment looks much better now. Sigh, no driving until the injectors return. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
jim912928 |
Apr 9 2006, 08:38 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Started parting out my donor carrera so I can transplant the 3.2l engine in it. So far I've been taking parts off over the past week and sold 8 items...i'm 1/5 the way to break even and have hardly sold anything. Man, it's amazing what people will pay for used 911 parts!
michel richard |
Apr 9 2006, 08:44 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
Fabricated some parts for my 901 tranny oil cooler project. Making progress. I've got a thread on it.
erikstoll |
Apr 9 2006, 08:45 PM
Just Another Roadside Attraction Group: Members Posts: 171 Joined: 30-November 05 From: Reno, Nevada, USA - The Biggest Little City In The World Member No.: 5,210 |
i got the power window fixed (new motor and regulator installed) on my Mitsubishi Galant (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
rmital |
Apr 9 2006, 08:51 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
POR15'd the heck outa the car. How do you get to the area below the headlights. Where the drain tube passes thru to the bottom of the car?
....welded in battery tray....finally. I almost feel like I'm getting close....to....finishing.....whatever that really means..... |
Lo-Fi Version | Time is now: 21st May 2024 - 04:52 AM |
