4 bolt spacers, got any sources |
DanT |
Apr 9 2006, 11:35 PM
good sources for 4 bolt spacers.
1/4- 3/4 inches in width need to fill out my pulled-rolled fenders just a bit more (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) also need source for longer lug bolts Thanks |
Aaron Cox |
Apr 10 2006, 08:31 AM
a guy on ebay will make you hubcentric spacers OR adapters....
not cheap |
john rogers |
Apr 10 2006, 09:00 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I got mine from CB Performance, formally Clyde's Buggies.
Eric_Shea |
Apr 10 2006, 09:48 AM
If those don't pan out, our 5mm spacers are drilled for 4 or 5 lug.
$59.00 a pair (see them in the V-Caliper thread) |
Mueller |
Apr 10 2006, 10:36 AM
I have 2 1/2" spacers ready to go if that'll work for you..you can test fit if you want....
(IMG:http://www.914world.com/bbs2/uploads/post-2-1110164290.jpg) |
DanT |
Apr 10 2006, 11:17 AM
Thanks for the offer Mike....those are just a wee bit too wide. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Actually my perfect size would probably be about 1/2 inch but 3/4 would probably work. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) I'll keep yours in mind Eric. Not in any hurry, just started my search.... does anyone know the name of the guy on ebay that makes the custom ones? |
Mueller |
Apr 10 2006, 11:21 AM
what are you putting in you morning coffee Dan?? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Those spacer in the picture is .500" or 1/2" or 12.7mm which is your minimum requested size (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Let me rephrase it: I have 2 spacers, they are 1/2" thick (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Brett W |
Apr 10 2006, 11:26 AM
Find some old junk rear rotors and take them to a machine shop. Have them machine the hats off and leave just the mounting face. Voila' instant spacer. I think they are .500. I used them to push my rear wheels out to fill out the flares on my car.
DanT |
Apr 10 2006, 11:31 AM
Mike,
Ah....now I see. I guess I was reading your post a little fast (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) ....... and I don't drink coffee, really. O.J. or milk.... what lenght studs are you using with those? |
STL914 |
Apr 10 2006, 11:32 AM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Mueller |
Apr 10 2006, 11:37 AM
did you even look at the price of those?? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) besides, common practice is nothing thinner than 1" for spacers that use secondary studs for mounting. //////////////////////////////////////////////////////////////////////////
no coffee?, oh no, couldn't do it..... I cannot remember, I'll measure them for you...those are the BBS Racing screw-in studs |
Dave-O |
Apr 10 2006, 11:54 AM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
I just ordered a set of longer lug bolt from here
I'll let you know what I think when I get them. I had a set of spacers made for my fronts at a machine shop. I'll post pictures when I get home. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:35 AM |
