It's back on the road!, But can I make it to hershey? |
Jaiden |
Apr 10 2006, 07:53 AM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
I finally got the teener back on the road! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
The last minute detains were the fuel system I added a small pressure guage and a second filter by the carbs that's clear so I can double check the flow. My Facet is running 6 psi I did a rough toe alignment and she's at 1/16th toe in and drives super straight! The brakes feel good but could probably use another bleeding and I need to get the shifting alittle better. I swapped the clutch cable and fixed the clutch tube so I probably need to adjust the clutch a little more but hey it drives!!!!! I drove it down my street to test everything out now I must recheck all of the bolts/ adjustments etc... Oh yeah and put a pedal assembly on the list of next things to do. Man is there anything that doesn't fall apart on these cars??? |
JoeSharp |
Apr 10 2006, 08:17 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
No! :PERMAGRIN: Joe |
Lo-Fi Version | Time is now: 21st May 2024 - 10:41 AM |
