I finally got the teener back on the road!
The last minute detains were the fuel system I added a small pressure guage and a second filter by the carbs that's clear so I can double check the flow. My Facet is running 6 psi
I did a rough toe alignment and she's at 1/16th toe in and drives super straight!
The brakes feel good but could probably use another bleeding and I need to get the shifting alittle better. I swapped the clutch cable and fixed the clutch tube so I probably need to adjust the clutch a little more but hey it drives!!!!!
I drove it down my street to test everything out now I must recheck all of the bolts/ adjustments etc...
Oh yeah and put a pedal assembly on the list of next things to do.
Man is there anything that doesn't fall apart on these cars???
