Monster Fuel Lines |
ChrisFoley |
Apr 13 2006, 07:50 AM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
During my recent fuel line sale some people asked about larger lines for big engines. I didn't get enough response to justify buying 7/16" tube and a bender, but I just happened to have some 1/2" stainless tube and a bender for 1/2"dia. One customer asked for larger lines with AN fittings so this is what he got: 1/2" supply line with 3/8" return.
(IMG:http://www.tangerineracing.com/images/EnginePics/Monster%20Lines%20Rear%20End%20with%20Fittings.jpg) |
iamchappy |
Apr 13 2006, 07:59 AM
Did that request come from someone with a name starting with Q?
michel richard |
Apr 13 2006, 08:04 AM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
Chris,
Do you have an idea of how much hp the stock lines will support, the 7/16, the 1/2 ? My new engine will have something like 225 or 250 hp, will run PMO carbs. I've been thinking that I should upgrade my fuel lines. |
goose2 |
Apr 13 2006, 09:31 AM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
Chris...I had hoped to get in on the fuel line frenzy but I guess I dropped the ball somewhere. Can I still get a set of stock size lines from you?
Qarl |
Apr 13 2006, 10:30 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Nope...not from me...
smdubovsky |
Apr 13 2006, 12:59 PM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
Typically AN6 hardline (which is '6'/16 = 3/8 OD) will support ~500hp. AN8 (='8'/16 = 1/2) is good for ~750hp. This probably assumes the pump near the tank (plus it goes up and down depending on your BSFC but they are good rules of thumb). Id like a ride in a teener that actually NEEDS AN8 lines;)
SMD |
Brian Mifsud |
Apr 13 2006, 01:30 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
Chris, check your PM
Lo-Fi Version | Time is now: 21st May 2024 - 04:30 AM |
