ChrisFoley
Apr 13 2006, 07:50 AM
During my recent fuel line sale some people asked about larger lines for big engines. I didn't get enough response to justify buying 7/16" tube and a bender, but I just happened to have some 1/2" stainless tube and a bender for 1/2"dia. One customer asked for larger lines with AN fittings so this is what he got: 1/2" supply line with 3/8" return.
iamchappy
Apr 13 2006, 07:59 AM
Did that request come from someone with a name starting with Q?
michel richard
Apr 13 2006, 08:04 AM
Chris,
Do you have an idea of how much hp the stock lines will support, the 7/16, the 1/2 ?
My new engine will have something like 225 or 250 hp, will run PMO carbs. I've been thinking that I should upgrade my fuel lines.
goose2
Apr 13 2006, 09:31 AM
Chris...I had hoped to get in on the fuel line frenzy but I guess I dropped the ball somewhere. Can I still get a set of stock size lines from you?
Qarl
Apr 13 2006, 10:30 AM
Nope...not from me...
smdubovsky
Apr 13 2006, 12:59 PM
Typically AN6 hardline (which is '6'/16 = 3/8 OD) will support ~500hp. AN8 (='8'/16 = 1/2) is good for ~750hp. This probably assumes the pump near the tank (plus it goes up and down depending on your BSFC but they are good rules of thumb). Id like a ride in a teener that actually NEEDS AN8 lines;)
SMD
Brian Mifsud
Apr 13 2006, 01:30 PM
Chris, check your PM
