torsion bar spring rates |
machina |
Sep 17 2003, 03:14 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Found this chart on a 911 site. Numbers should be the same for 914's. Suprising how much the rate increases with each mm. The difference between the two numbers has to do with where the value of the bar is measured, at the wheel or the bar itself. I did not think that my 21mm bars would have such a high value (227/249)
dr Front Rates Torsion Kw (lb/in) Ks (lb/in) Dia (mm) (Wheel) (Spring) 16 77 90 17 97 112 18 122 138 18.5 137 154 19 152 170 20 187 207 21 227 249 22 273 298 23 327 355 |
ArtechnikA |
Sep 17 2003, 05:47 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(synthesisdv @ Sep 17 2003, 01:14 PM) Suprising how much the rate increases with each mm. rate increases with the 4th power of diameter, all else being equal. there's also a formula for hollow bars -- the center of the bar weighs something, but does essentially no work. somewhere i have my Carroll Smith and Paul Van Valkenburgh books but i haven't unpacked them yet. gotta do some of that tonight in the process of making room in the garage for the cars before what's left of the hurricane hits sometime Friday morning ... |
machina |
Sep 18 2003, 06:20 AM
The numbers looked higher to me because of what most people tend to run on their cars. Seems like many people run 21mm up front with only 140 or 180 springs in the rear.
My experience with 911's and my mid engine sport racer tells me that the spring rate at the rear should be higher than the front, not lower like our cars seem to be set up. I would think that for a road race setup, 21mm bars up front should match with 225 => 250 in/pound rear springs, and then a heavy front sway bar. dr |
Lo-Fi Version | Time is now: 29th April 2024 - 09:42 PM |
