Where does your temp needle sit?, For '74 and later cars? |
Chris H. |
Sep 17 2003, 03:41 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Just a quick question... I have a '75 1.8L and recently swapped the incorrect '73 console temp gauge with the correct one which has the much smaller "red zone". It seems like the needle reads much higher than the old one. It's lined up with the "p" stem in TEMP at operating temperature. Not into the red at all, but higher than the last one read. Where does yours sit normally? Guesstimates welcome.
Thanks, Chris H. |
nebreitling |
Sep 17 2003, 06:24 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
last time my car was at HPH, I had them take the oil temperature after they had warmed it up. they were able to tell me that when the needle pointed over the "E" (of "TEMP), the oil was 200; at "M", it was 210. obviously, this technique isn't the most ideal, but it gives me a baseline to work from.
my 75 2.0 use to run up towards the red (probably around 225 or 230) and would overheat if i let it. removed the rain tray, helped a little. removed the airpump. that helped some too. replaced the old HE's with a decent used set, new muffler (the old one had all sorts of holes in it), and bypassed the EGR system: now, on all but the hottest days or steepest hills, it doesn't crawl much above 210 -- and usually is more towards 205 (between the "E" and the "M"). good enough for me. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:13 PM |
