Wide Band Commander, Getto install, no really |
newto914s |
Apr 14 2006, 11:46 PM
Senior Member Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
This is supposed to be super temperary. 10 minutes on, 10 off if need be. I'm going to use this to TRY to get some base reading on the d-jet. So if/when I start to make mods I can keep it all close to tuned.
Control box Attached image(s) |
newto914s |
Apr 14 2006, 11:49 PM
Did I mention Getto. It needs an ignition on power line. So I ran it off the line to the radio (IMG:style_emoticons/default/biggrin.gif)
I wired a fuse in their too. It should sit right on the pagenger's sholder Attached image(s) |
newto914s |
Apr 14 2006, 11:51 PM
I accualy have a O2 bung to weld into the exhaust, but no welder. So my Dad rigged this up.
newto914s |
Apr 14 2006, 11:53 PM
Here it is in action. Yes, it hose clamped to the tail pipe.
newto914s |
Apr 14 2006, 11:57 PM
Half way throught the install my brother showed up with a new car for his wife. It's kind of like give a bowling ball with your name on it. It a new 2005 Legacy GT. Same 2.5 that's in the STI just a little detuned. He got it for $23.5k. Is that a screeming deal or what! (IMG:style_emoticons/default/drooley.gif)
newto914s |
Apr 15 2006, 12:00 AM
Dad to help smell for burning wires when I reattached the battery. Mom for moral support, she must know something about these cars (IMG:style_emoticons/default/idea.gif)
newto914s |
Apr 15 2006, 12:04 AM
Last one of the set-up. I figure I'll tie it to the grill and the gauge will reach in through the passanger window. Not super conserned about reading it, cause the divice can data log to it's internal memory and be downloaded to a laptop later.
newto914s |
Apr 15 2006, 12:07 AM
I did start it for about 2 minutes, and the gauge was reading around 16-17. It would blip down to 14 when I gave it throttle but then come back up. Strange, concidering it should be in warm-up mode and running rich right? Maybe, it's reading lean because of how close the sensor is to the outside air? I'll have to wait till tomorrow to test some more.
Twystd1 |
Apr 15 2006, 12:11 AM
I can tell you that the last time I tried to use the end of the exhaust for a o2 reading..... it was WAY off in the comparitve analysis to the bung/weld install.
I know.... I used rolling dyno for both installs. The same day... the same dyno... And compared the two with a Horiba gas analyzer. (the bomb) The bung install was relatively close to the Horiba. The tail install was terrible. And inaccurate. The o2 gets contaminated with air as the pulses go out the tailpipe. Therefore. I got BAD readings. Thats just my experience. Yours may be differant. |
newto914s |
Apr 15 2006, 12:18 AM
That makes a ton of sense Twystd1. If I don't get better results after the car warms up a bit. I'm going to go the bung route. Do you think putting it in the Cat bypass pipe would be far enough up the exhaust to get accurate readings?
Twystd1 |
Apr 15 2006, 12:21 AM
HHHmmm.. I don't know what a cat bypass pipe looks like. or where it is for that matter..
Ya got a pic???? Twystd1 |
Twystd1 |
Apr 15 2006, 12:24 AM
By theway. is this a PRE-Heated sensor? (3 or 4 wire)
o2 sensors have heat ranges that they are more accurate. |
newto914s |
Apr 15 2006, 12:29 AM
Right were the gap is, is where the bypass pipe goes. So around in there.
I believe it has 4 wires. I know it self heats, and instruction say you should not run the car with out the unit getting power. Attached image(s) |
DonTraver |
Apr 15 2006, 07:16 AM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
My RSA and other cars where I've replaced the O2 sensor always had the sensor before the cat. The cat scrubs the exhaust to reduce emissions, so after the cat could give false readings too.
Good Luck, Don |
DNHunt |
Apr 15 2006, 07:27 AM
Weld a bung in before the muffler as close to where the pipes join into 1. You should be able to get a muffler shop to do it pretty cheap cause it only takes a second. When you aren't using the O2 sensore stick an old spark plug in as a plug.
Here's an idea. If you run rich you could rig up an extra coil back there with a switch and blast the hell out of the people behind you. (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) Dave |
Bleyseng |
Apr 15 2006, 10:12 AM
From the pics of the muffler you are still running the late style HE's so that is a good idea to install the bung in the CAT test pipe. Should give you good readings compared to the pos tailpipe mount you rigged up.
Drill the hole yourself first then take the pipe to the muffler shop to weld in for a few bucks. 5 min job. also, rip out that ratty firewall pad as water gets in behind it and rusts out the firewall. |
DNHunt |
Apr 15 2006, 10:19 AM
(IMG:style_emoticons/default/hijacked.gif)
By the way Gerry and I ran kind of a crazy tune down in Portland a few weeks ago. The result was when Gerry was on the skid pad and got off the throttle and then back on it lit off some extra fuel in the exhaust. Nice loud pop and about a foot long in the daylight. Too bad it wasn't at night. It would have made for some good entertainment. Needless to say we junked that file and are running a little more conservatively now. Dave |
Bleyseng |
Apr 15 2006, 10:23 AM
Now that file should be labeled as "Tailgater remover Stage One"
Worked fine on the RX7 Turbo! |
DNHunt |
Apr 15 2006, 10:34 AM
It's already in the recycle bin. Gerry put on a good show. He had the inside wheel spinning and the ass end out so there was plenty of smoke. Add to that a couple of good pops and a little flame and dad's anal sphincter got a little tight.
Dave |
newto914s |
Apr 15 2006, 12:53 PM
I looked around, and I can't seem to find that bung(moving sucks). So I added a little extention to the pipe and it brought the reading down to 13.5. I'm not really sure what I should be shooting for. I'm going to try connection the laptop to see if I can set it up and grap some data
Lo-Fi Version | Time is now: 22nd May 2024 - 12:17 AM |
