wbergtho |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 ![]() |
I have labored for quite some time on the new hydraulic clutch system I have been working on and I felt it was ready to be bled and tested on the road. It appears that no fluid will get to the slave until I first bleed the m/c (per Tilton's instructions). I even took the brake line off @ the m/c and nothing would squirt out. The bleed screw may as well be on the moon. I can't get a wrench or socket on the damn thing and might have to take it out and cut one of the unecessary mounting ears off to effectively reach it with a wrench. Has anyone been there and done this with a Tilton m/c? I thought I could just bleed the slave and get 'er done. Looks like it is a bit more involved than that. Apparently this m/c must be "primed" via bleeding in order for it to squirt fluid? I'm done fu__ing around with it tonight.
Bill (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:28 PM |
