Anyone know where I can get a fitting, To connect 3/8" steel tube to an AN-6 hose? |
billd |
Apr 16 2006, 02:12 AM
Member Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 |
I'm about to start plumbing the fuel system for my 914/6 conversion and my plan is to run 3/8 inch steel hard line from the tank back to the engine compartment and then run Aeroquip AN-6 socketless hose from there. The problem is that I can't find a fitting to connect from the 3/8 inch tube to the AN-6.
The 3/8 inch brake line is finished in an inverted flare with a 5/8-18 barrel with male threads. The AN-6 hose ends in an AN-6 female fitting. Someone must make an adapter to connect these two ends together. However, I can't find one. I could cut the line and replace the male barrels with an AN 818 female barrel and AN 819 sleeve, but I'd rather not have to cut and then reflare the line. Any advice would be appreciated. |
Pistachio |
Apr 16 2006, 04:05 AM
Newbie Group: Members Posts: 49 Joined: 7-March 06 From: People's Rebuplik of Kalifornia Member No.: 5,684 |
Take a look at the adapters made for Power Steering.
I know Earls makes a male/male, IF 5/8" 18 to -6AN. So to use that, you'd need to run from your existing tube/fitting, into an IF coupler (easy to find) , then the adapter, directly to your AN fitting (if I understand your plumbing dilema). Check out: AN Plumbing. Believe the part # you're looking for is 991947 or Russell PN 640380 |
Pistachio |
Apr 16 2006, 04:10 AM
Oh, & for what it's worth -
Cutting off the IF fitting & using an AN tube nut & sleeve would be a much more elegant solution IMO If you don't have the AN flare tool, I can understand your desire to use an adapter. On the other hand, if you'd buy the tool now, you'll never find yourself in this same hardline-flexline "I can't find an adapter" fix again. |
wbergtho |
Apr 16 2006, 10:40 AM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
Try Pegasus Auto Racing Supplies @ 800 688 6946. Tell them what you are doing and they will probably have the correct fitting. Good customer service.
billd |
Apr 16 2006, 01:57 PM
Cutting off the IF fitting & using an AN tube nut & sleeve would be a much more elegant solution IMO After thinking about it a bit, you are absolutely right. Its better to do this the right way - with just the one fitting, than to stack up a bunch of adapters. I'll get out the tubing cutters and flare tool. |
Lo-Fi Version | Time is now: 15th May 2024 - 03:15 PM |
